    @Boldline The problem here is the lack of modifier keys for this feature. The Pen tool already uses all modifier keys.
  • Can Erase Block modifier respect selections?
    @Boldline Can be replicate here also. Seems to be a bug, somehow the block eraser mode also selects the objects.
  • Make empty Layers clearer
    @debraspicher I added this to the backlog. The arrow has to stay to indicate that there is a content (even if empty) inside the object. This is not just for layers, but if you drag an object into an other and then drag it out, it will result in an object with an empty content (Group item will show up in the Appearance panel).
  • Quick alignment of text on a path with uneven beginning/end shapes
    @debraspicher, @VectorStyler Coreldraw handle something like this via Text selection Text on Path Text selection in VS [image: 1718440128715-vectorstyler-text-on-curve.png] . . Text on Path selection in CorelDraw [image: 1718440157954-coreldraw-text-on-curve.png]
  • Duplicating Artboards lead to overlapping bleeds
  • Could Unicode character box in Glyph panel be more interactive?
    @Harry I added this to the backlog.
  • Missing custom style in halftone within the image effects
    21
    31k Views
    @Li-Xiao In my opinion, the fusion effect is not suitable for replicating something like this. Because it only works well with shapes that are the same size and an contour/outline is needed. [image: 1718259393554-fusion-effect.png]
  • Appearance Groups and Repeaters?
    @fde101 I will try to find a way to do this. Certainly not through the Shape Effect panel, as those can alter shapes only (not styles).
  • Creating Shape Paint artwork using the Shape Paint Tool
    @VectorStyler said in Creating Shape Paint artwork using the Shape Paint Tool: @William-Kansepa We could create the Shape Paint object at the first click, from the selected objects. Would this be suitable? Yes, that is exactly what I meant. Thank you.
  • Idea for functionality of a built-in note text file in VS
    @Boldline I added this to the features backlog.
  • My mini wishlist
    @William-Kansepa said in My mini wishlist: list item.tif file format export. At present VS only has the .tiff option. Although not highlighted in the release notes, this issue has been addressed in VS 1.2.027. I can now export *.tif in VectorStyler. Thank you @VectorStyler!
    @Boldline The "Separate Offset" refers to the object selection, do we apply the offset separately on each or on the whole as a single object. The "Combining" option refers how to treat the one object (and the combined object if separate is not checked). Not sure yet if these two could be merged into a single option.
  • Can Pasted Live text be added to the "Recent Fonts" automatically?
  • Disturb colors?
    @Ingolf I added this to the backlog.
  • About the action panel
    @VectorStyler You are very powerful and worthy of admiration.
  • Consolidate the Color Panels under the Panels menu?
    @VectorStyler said in Consolidate the Color Panels under the Panels menu?: @Boldline Would it be under a sub-menu? Cannot make a single panel out of these, as it would create confusion. Correct, I was implying they would be under a sub-menu. I should have elaborated further. I was envisioning the color choices in a sub menu similar to how some others in the Panels menu are set up, like "Text" is currently [image: 1716991122555-36eec787-4a7e-4d02-88a7-77fc50bb8156-bld-2024-05-29-at-09.57.43.png]
  • Smart ways of image replacing
    @VectorStyler said in Smart ways of image replacing: What if in case of a single file import, and if a single image object is selected, the Place tool is not activated, but the image is replaced? I used to prefer this earlier behaviour in VS, but it has since been changed...
  • Add a direct link to the backup file location in the help menu?
    @VectorStyler Thank you. I was giving this a little more thought. To me, it would also make sense if the settings preset file was also available for direct link. I don't know if the best place for that is in the help menu because the user is more likely to have their own separate custom location for custom settings presets, maybe an option in the settings panel with a direct link to where the file is stored? [image: 1716904218981-df33567b-fa1a-4c91-a259-7ddabc914577-cleanshot-2024-05-28-at-09.47.40.png] [image: 1716904887672-93987ac0-e2cf-485b-92ed-99efbc81d4f1-cleanshot-2024-05-28-at-10.00.51-resized.png]
  • A better way of aligning Shape/Point Text
    @William-Kansepa said in A better way of aligning Shape/Point Text: e.g. Align Left to Align Centre, the text shifts and does not maintain x coordinate. The problem is that in VS (as in AI) the text is aligned relative to a text position. This is not possible to change for now, but I will try to find a way to automatically "move" the text when alignment is changed (in some cases).
