      Windows - Cannot snap resize the program
      @Mongeuse This problem should be fixed in build 1.1.048
    • Victor VectorV
      Text Menu > Text Shape/Frame Title Inconsistency
      @Victor-Vector This problem should be fixed in build 1.1.048
    • Devil DinosaurD
      Linked Greyscale Image issue (semi resolved)
      @Devil-Dinosaur This problem should be fixed in build 1.1.048
      Slider in the Shape Panel has no usable range
      @Subpath This problem should be fixed in build 1.1.048
      Minor issues with german umlauts "üäö...."
      23k Views
    • Victor VectorV
      Text Frames copied with CRTL+D cause performance hit when text is edited.
    • encartE
      Panning with the mouse wheel breaks the path
      @encart This problem should be fixed in build 1.1.048
    • IngolfI
      Transparency via keyboard stops working (.26)
      @Ingolf This problem should be fixed in build 1.1.048
      Extra base lines appear when grouping multiple pieces of live text
      @Boldline This problem should be fixed in build 1.1.048
      Anchor Point tool does not seem to work at all in build 26
      Issue in snapping.
    • IngolfI
      Closing object while dragging - other node affected
    • IngolfI
      Control + backspace deactivates input mode
    • IngolfI
      Codepage mismatch in taskbar
    • N
      Available shape style overrides list not showing any styles ( accumulated )
      @Nils This problem should be fixed in build 1.1.048
    • N
      Changing member of grouped clone original hides clones ( accumulated )
    • N
      Symbol instance goes transparent when switching canvases ( accumulated )
    • N
      Canvas role "Object style" doesn't work, others do ( accumulated )
    • N
      Change to applied shape style override doesn't propagate ( accumulated )
      Font dropdown list glitch (Windows)
      20k Views
      @Gremriel Yes, I was able to replicate the issue by changing the UI scaling settings in the preferences.
