      the "interaction indicators" section of the preferences does not seem to have a dropdown for options
      @Boldline This problem should be fixed in 1.1.048
    • U
      Unable to paste snapshot
      @umauma This problem should be fixed in 1.1.048
      Composite Object Bugs ?
      @Subpath This problem should be fixed in 1.1.048
    • Victor VectorV
      Transparency Mask Shape Delete Issue
      @Victor-Vector This problem should be fixed in 1.1.048
      Offset path places itself underneath one selected object, but not the others
      Stroke option inside Offset Path Panel does not stay current
    • Victor VectorV
      Guidelines don't snap to Grid
      Trying to paste a copied object often results in a prior copied selection being pasted instead
      Copy and Pasting of Text on a Path Not working
      @Boldline Is this problem still persists?
      Context bar
    • Victor VectorV
      Artboard Placement Y-axis issue
      Opening Illustrator files stops loading and eventually shuts down VS
      Spacebar to pan around is not working consistenly
    • IngolfI
      Pen tool .34 little distraction bug
      @Ingolf This problem should be fixed in 1.1.048
      Failing to access Windows taskbar
      24
      47k Views
      @William-Kansepa This problem should be fixed in 1.1.048
    • IngolfI
      Keep selection is not working (regression in .30?)
    • IngolfI
      .32 regression - draw above acts as draw below
    • IngolfI
      Critical bug (.32 regression) - cannot close curves with pen tool
      Pan with Spacebar seems to occasionally stop working
    • encartE
      0.33 Object > Simplify Path does not work.
      @encart This problem should be fixed in 1.1.048
