    • Victor VectorV
      Edit Cap, Edit Arrow - "Space" field does not recognize a typed negative value
      @Victor-Vector This problem should be fixed in 1.1.048
    • Devil DinosaurD
      Object partially masked doesn't render at export
      @Devil-Dinosaur This problem should be fixed in 1.1.048
      Toggling the Transform panel from the panels menu hides or moves contextual menu bar instead
      @Boldline This problem should be fixed in 1.1.048
      Cusp Retraction shortcut causes strange results
    • encartE
      Polish diacritical marks require double press
      @encart This problem should be fixed in 1.1.048
      Sometimes the shape tool does not create a shape on the canvas
      @Boldline If the problem still persists?
    • IngolfI
      When tracing a bitmap with image effects applied brightness goes up and down
      @Ingolf This problem should be fixed in 1.1.048
    • IngolfI
      Draw above bug
    • Victor VectorV
      Image Effects Filter - "Opacity Values and Mask" Drop-down UI glitch
      Composite Shape
    • I
      Color palette UI little bug
      @ideagonal This problem should be fixed in 1.1.048
      Closing path messing up first segment
      @gentlecl This problem should be fixed in 1.1.048
      Layer panel , colour selector issue
    • IngolfI
      Unexpected and unwanted color mode changes
      @Ingolf This problem should be fixed in build 1.1.048
      Cutting live text and pasting it in the document does not work
      @Boldline This problem should be fixed in build 1.1.048
    • IngolfI
      macOS - Paste Inside replaces objects when clipboard contains raw text
    • Victor VectorV
      Automated email bug reporter after crash sends email when the "enter" key is pressed.
      @VectorStyler I encounter crash with pen tool, but when restart the program bug reporter poped up.
      Pen tool crash the program
      @Jayanta-Das This seems to be a regression in the Apperance panel.
    • IngolfI
      Adding image effects to locked layers - usability
    • IngolfI
      Double path in outline mode
