    282 Topics
    228 Topics
    XRAYX
  • Repeater selection using gradient is not working as expected
    @EricP Thanks, that was helpful. I'm so used to using the repeater the way I do that I completely forgot about the other options. By the way, I'd never tried the Selection option you showed in your post above before. Very interesting. Thanks for that as well.
  • Repeater is not always linking symbols
    1k Views
    @EricP The shape can still be selected: in the Layers panel, open the repeater, and select the object inside. But it will show it at the center of the repeater.
  • antialiasing with TIFF export 4K 600 dpi
    @ZATOPEK Did not upload the file for some reason. Can you send it to me by email to support at vectorstyler.com
  • Exporting a VS document as pdf with symbols returns a mess
    @VectorStyler Just updated VS. It seems to work fine now
  • Reference artboard, symbol...
    1k Views
    @VectorStyler I've sent you a file but I didn't test all issues.
  • Unexpected offset when swapping symbols
    @VectorStyler Confirmed
  • Stroke width will be scaled on every imported File
    1k Views
    @Subpath said in Stroke width will be scaled on every imported File: Does that mean there is no way to turn this effect off? There is, individually for each stroke
  • Shape/symbol disappears, no undo available and VS subsequently crashes
    @Raaskot I opened a bug on this and will try to fix it ASAP.
  • list of errors
    46
    33k Views
    @VectorStyler The outline effect is fine. I just realized I accidentally turned off the eye icon while operating.[image: 1760625721249-mmexport1760625669307-resized.jpg] By the way, could you help me figure out why this function in my workspace isn’t working?
  • copy multiple objects with the right mouse button doesnt work anymore
    1k Views
    @Subpath I will try to fix this ASAP.
    1k Views
    @VectorStyler said in Control key modifier when moving node, the bottom right node moves as well: @Boldline It should work with holding Shift. If I use shift, it does not want to cooperate and go straight upward. UPDATE: I had "constrain line angle" checked. When I turned this off, it allowed for shift to work as intended. [image: 1759855207120-90a63bef-fe52-4cce-85d2-a1656a1702a7-cleanshot-2025-10-07-at-12.38.27-resized.png]
  • Shape effects are lost on copy/paste
    @VectorStyler https://youtu.be/7PFPP9QXqNA?feature=shared 0_1759503919233_556.vstyler
  • Unable to copy / paste formatted text between documents
    @MWK Can be replicated here also, I will try to fix this
  • No cmd-v (or -c) file names when saving to new file
    1k Views
    @Raaskot This is an open issue still (has been for some time). I will try to find a solution
  • 2 minor issues
    Devil DinosaurD
    @VectorStyler , yes, that works.
  • Missing samples in the palette panel
    @VectorStyler Latest build fixed the problem. Thank you so much
  • Sharp Corner - Option Key not working?
    O
    @VectorStyler Just updated to VS version 1.2.083. Bug fixed and option key with Sharper Corner works! Thank you.
  • Missing artboards in Canvas Data Grid
    @VectorStyler said in Missing artboards in Canvas Data Grid: There is also batch export support to export files with variations (rows) from a data source, without the need for creating canvases Ok, thanks. For future reference for other users: This method works for artboards also, but in Canvas / Canvas Data Grid, "No Data" option should be selected. Still, I have to experiment with the template canvas!
  • vertical toolbar drops to bottom of screen when detached
    @Boldline I tested with the previous settings file and cannot replicate it. Send me the ones where this occurs.
  • Difficulty selecting inner shape
    1k Views
    @VectorStyler just realized the link was broken in my original post. Even though you seem to have it replicated there, I'll still post the video again
