    282 Topics
    228 Topics
    XRAYX
    @brentpruitt I added this to the backlog.
  • Move Character and Paragraph Style panels to Text menu
    @VectorStyler I understand. Perhaps move them to Window/Text then. Makes more sense. [image: 1752134187028-87b601d1-e629-4b23-8721-29801080fe2c-image-resized.png]
  • Possible Error in Properties Panel Transform > Scale
    @Wolfgang Yes, this seems to be an error, the field has the wrong lower limit. The Transform panel should display the correct scale. This will be fixed in the next build
  • Bugs on node editing
    @VectorStyler Thanks very much
    @Boldline I tested this with a simple example, but could not replicate it. Send me a sample by email, where expanding a clipped group cannot be undone. Might be caused by some specific object attribute.
    @Raaskot Yes, I remember there were mesh exporting issues with PDF. I will try to replicate and fix these.
  • Forum bug?
    Okay, I've been keeping an eye on that. It only appears for the last thread in the list of unread posts. To my surprise, it also appears when I open the topics in the list in a new tab. So the last tab with the last topic in the list took a while to load. I don't know exactly. But I'd guess it was 15-20 seconds. All the others loaded instantly. I was using Firefox.
  • Pdf-file: no show on loading
    @VectorStyler Ignore previous. After restart of Mac I cannot replicate it either, and it seems to work fine all over. If it appears again I'll let you know.
  • Log
    @monsterfox Yes, it is the same here. I will try to improve this. There are over 400 objects, doing this in smaller sets might be faster.
  • UI error; Layer names in list dissapears on double click
    @Raaskot On mac they should be in: ~/Library/Application Support/VectorStyler1.2/vector/data/resources/ folder But for Mac App Store version, these folders are well hidden by MacOS and different for every user. You can also try the Help -> Reveal Workspace Folder command.
  • Font previews don't work
    @VectorStyler Yes. I keep font collection on my drive and added some folders via Font Manager.
    @Boldline I cana replicate this issue here also. Select the Object -> Shape -> Clear Shape Builder State, this will reset all previous shape builder states.
  • Bug
  • HSL sliders behaviour in CMYK document
    @VectorStyler lot's of options. That's great. Thanks for this great software and your perfect support
  • Rotating a Repeater object causes a crash
    @VectorStyler No more crashes when rotating. Thanks!
  • Rounding Tool
    1k Views
  • Two Bugs
    @VectorStyler https://youtu.be/uQ7xkmFEKWQ?feature=shared
  • Four errors
    @monsterfox said in Four errors: When using the rounded corner tool in Outline mode, ghosting was found I opened a bug on this.
  • Gradient copy paste to Affinity
    thanks for the bug fix in last release. Fantastic support !
  • Node Bump's “Randomized” issue
    @VectorStyler Thanks for the fast fixes.
