    292 Topics
  • The Danish hyphenation is utterly bad
    The text block comes here ... @VectorStyler 0_1731592252933_01.vstyler
  • The EPS output to PS is not fully displayed.
    @VectorStyler Only for PS
  • [Data Source] Bugs and request
    @VectorStyler Indeed, fixed. thank you
  • Holding Shift while snapping disables snapping to objects
    @VectorStyler Thanks, it works now
  • Gradient mesh fails on pdf-export
    @VectorStyler Great, thanks
  • The position changed when repeat scale
    @VectorStyler Fixed. Thanks.
  • A minor issue with using number variables on the Context Panel
  • Bucket Fill tool registers as "Shape Builder" in History panel
    @Boldline This issue should be fixed in build 1.2.046
  • Toolbar repetition
    @monsterfox This issue should be fixed in build 1.2.046
  • Issue with alignment of objects along a stroke
    @B-Vs-V Alignment on path with rotation inside transformed groups will remain an open issue for now. But without rotation it should work.
  • dashed lines.
    @VectorStyler Am I not seeing it? I was just beginning a reply post to let you know I did not see in when the auto-update offered me a new build update. and I see it there now. thanks!
  • Angle/Rotation in contex bar seems buggy
    @VectorStyler It is indeed a little confusing, especially when you use it with grouped objects
  • Wrong type size value display in SVG import
    @VectorStyler said in Wrong type size value display in SVG import: Is the text in a layer or group that has been scaled ? All imported is grouped. Transform panel says that objects are 24% scaled. Didn't do any editing in VS, just imported.
  • The Wave Grid and Zigzag Grid Spacing Issue
    Fixed. thanks
  • History issue with cloned objects (?)
    @Pat said in History issue with cloned objects (?): Although they are clones, I don't understand the chaotic distribution of objects It calculates the movement and rotation of each clone relative to its original. But the original will be transformed by then. The effect is the accumulation of two transforms (wrong) with a wrong rotation center. I will fix this in the next build: the alignment tool has to take into account that the objects are clones. A similar thing will occur with aligning sizes, or when working with references.
  • angle display box
    @monsterfox Will be fixed
  • Using Adobe PDF (and Microsoft Print to PDF) as a virtual printer
    @Arde said in Using Adobe PDF (and Microsoft Print to PDF) as a virtual printer: Another issue with Adobe PDF virtual printer is that it seems that it is not available in macOS version of VectorStyler. This might be available only on Windows (depending on the drivers provided by Windows). I will open a bug on the printing issues on Windows. The common PDF virtual printing mode of VS should be named "PDF File", this is available on both Windows and MacOS
  • Miss labeling and missalignement of labels
    @Mismo Some previous resource files were not replaced by the update. Please remove VectorStyler and reinstall as a clean install.
  • An error occurred while exiting the mixed state.
    @VectorStyler https://youtu.be/bQ_DdwRosxg?feature=shared The cloning property of "Duplicate" should be removed, otherwise a lot of abnormal errors will occur.
