    292 Topics
  • graphic replacement any Reference
    @VectorStyler That is the left - side graphic replacement tool.
  • ShapeBuilder and Divide Boolean have heavy lags
    @VectorStyler The video here shows how I did it Again the Boolean Merge before Boolean Divide works a bit better
  • PDF missing font window prevents VS from starting.
    @encart In the new build, the splash screen should close before any of the documents are opened (or the missing fonts view is shown). Is this the case for you also?
  • {UX} Editing Hidden Object in Appearance Panel
    @debraspicher If I understand correctly: the object gets deselected immediately after the change is applied. I will try to fix this for the next build.
  • Data Sources - VS freezes when importing single column text data
    @Harry Can be replicated here also, the fix will be in the next build.
  • "Reveal Backup Folder" not working
    This seems to be working fine for me. If I delete the "backups" folder and restart the app, a new "backups" folder will be created and shown.
  • Text scaling bug
    @encart Could be some option in the text, or a previous transform getting in the way. BTW: is the layer (in which the text is) transformed? Send me the VS file, I will try to find out what can cause this.
  • The disappearing figure
    @monsterfox I will reopen this issue with the second file and try to find a solution for the next build.
  • Cannot use the cursor/arrow keys layers names
    @Raaskot I will test these options.
  • Actions file can no longer be opened
    26
    35k Views
    @pentool said in Actions file can no longer be opened: The error here is that the edits are not saved immediately to the file. I will find a fix for this for the next build.
  • A few issues with the colors/color styles/presets
    I think this aspect needs a rework as it is very confusing to know what goes where and how everything ideally things are saved and recalled. I always assumed features were implemented as needed and would get a rethink as time went on depending on overall usability and feedback.
  • Odd Menu Jitter...
    @VectorStyler I think that is when I started observing it, also. Sorry, it gets busy so I can't always make the needed report. Usually it is easier on the spot but kept in mind if I can't get to it yet.
  • Updated: Masked mesh gradients --> bad pdf
    @Raaskot said in Updated: Masked mesh gradients --> bad pdf: pdf still fails concerning mesh gradients in masks Yes, this is not fixed yet. The problem is that PDF does not support meshes as masks. I tested this with Illustrator also, and it will create some vector approximation of transparent meshes. I think the only solution will be to export these as images. I will try to add it to the PDF export, to export this as flattened image.
  • Bug
  • Graphic Tablet and Windows Ink
    @VectorStyler As you can see in the recording above, every time I start to draw a new line, there is a slowdown after about 2-3 sec. The biggest problem is with curves, spirals, etc.
  • Wrong choice
    @monsterfox said in Wrong choice: Selecting the blue line and following the operations in the video will also select the red line on the left at the same time. I will try to replicate this.
  • Weird panel behaviour
    @nocturnalYL Got it.
  • "Mojikumi" misspelled in Preset Manager
    @nocturnalYL Yes, thanks!
  • Gradient stroke vs fill editing
    @pentool I opened a bug on this. EDIT: yes this can be replicated and it is a bug.
