    292 Topics
    @LoginError Yes, this is a known issue. It is caused by anti-aliasing when shapes are touching precisely and there is a different color background, then at the shapes margin this background will become visible. There is no other solution for now the turning off anti-aliasing.
  • Stretch the brush stroke.
    @monsterfox 不用担心,1.3就有中文了
  • Graphic replacement tool and Repeat panel。
    @VectorStyler https://youtu.be/AcYAcNuuG_E?feature=shared It is also a problem of the replacement tool. After using the graphic replacement tool, a clipping group will be generated in the replacement source, and it is hoped that it can be removed.
  • Trim Path
    @monsterfox I open a bug on this and will try to replicate it.
  • Panel showing behind tabbed Palette Panel
    @VectorStyler I'm sure you received it, but when I did the reset, the program reopened with a Crash report, so maybe that is a help.
  • Cannot Add Swatches.. or so it appears...
    @VectorStyler said in Cannot Add Swatches.. or so it appears...: @debraspicher I can only replicate the panel resizing issue. I can add colors to the palette, with a color selected from the color panel first. It is also possible to drag&drop a color from the color panel target knob (top-left fill/stroke thing) into the palette. I also tested this with the attached file. FWIW, I did test/check these methods. They weren't working either.
    @VectorStyler Sorry missed this. It's the result of the Undo/History bug. Sometimes this happens... I will keep recording and eventually I capture it. It's happened a few times. I'm not sure, but my guess would be the Object was originally meant to be a Layer... (I put everything in sublayers, generally) Edit: I wonder if my habit of Shift + {Click} New Layer/Sublayer might also add something not so nice to the History steps/recipe that might cause Objects that were moved around to get lost, as well? It's just a thought.
  • Adding swatches to default main color panel has issues
    @Boldline I will try to fix this for the next build.
  • Ghost Line request
  • Text Shortcuts not working
    @debraspicher said in Text Shortcuts not working: Are we 100% sure on that? Just because I was testing the Ctrl + V shortcut to see if it even worked at all and that's how I ended up with the Text Frame item Control+V is pasting on Windows. I meant the text frame conversion shortcut only exists on MacOS. What happened with the text frame: when a shape is selected and a text is pasted, then a text frame is created inside the shape, and the text flows into the shape. The problem was that this also happens when the selected shape is a text, and we get a text frame flowing inside the shape of a text. This is allowed in VS, but it should not do it when pasting.
  • The program crashes suddenly
  • Strange Behavior with UI in Settings Panel
    @debraspicher said in Strange Behavior with UI in Settings Panel: This blue line is visible in Settings and the Label is being clipped I will try to fix this.
  • Some bugs/quirks
    @Fertuffo said in Some bugs/quirks: Gradient fill expands limits to almost double the size when exporting in SVG. I could not replicate this (gradient fill svg export). Please send me a vstyler file that when exported to SVG results in expanded gradients, it might help replicating the issue. There could be a number of other attributes (transforms) that might cause this. Thanks!
  • Set style before drawing
    @Fertuffo said in Set style before drawing: @Fertuffo I mean, draw a line and try adding a new "Blue style". Then apply the "Blue style" to the same line and it turns non-value. This can be replicated, and it is a bug. Will be fixed ASAP.
    @VectorStyler said in Panel numerical slider does not show if panel is too close to screen edge: @Boldline yes, I think the new "slider alignment" feature made this worse. I will fix it ASAP. Sorry about that
  • Color palette panels grid margins
    @Ayo Seems that popup palettes do not use the option. I will fix this, and also place it into settings
  • Weird transform behaviour when altering fill color
    @Raaskot It is a refresh bug. Use Control+R (Windows) or Command+R (Mac) tor redraw. I will try to fix this ASAP.
