    292 Topics
  • Crash when editing gradient style color - UPDATE!
    @pentool Yes, seems that this kind of case was not fixed.
  • Crash when editing a gradient angle
    @pentool Replicated, will be fixed ASAP.
  • 16Bit Tiffs unsupported?
    @debraspicher This seems to be a bug.
  • Masked mesh gradients --> bad pdf
    @Raaskot It seems to be a bug, can be replicated here also. I will try to find a solution for this ASAP. EDIT: found the root cause, not yet sure when the fix can be available. The problem is caused by using transparent colors in the mesh gradient (these are not supported by PDF). I will try to fix this issue, but it might take some time.
  • Cosmetic issue - "Preset... Style..." menu order
    @pentool Will be fixed!
  • Color picker in gradient palette doesn't seem to work
    @pentool Yes, it can be replicated. I will try to find a solution for this. The problem is with the popup being closed before picking the color.
  • Cannot adjust gradient stop opacity through Stroke appearance
    @pentool Yes, this can be replicated. I will try to have it fixed before the next build.
    @Harry Tested it with the XP Pen tablet (deco1 v2) and indeed there are a lot of problems. It turns out that the XP Pen driver does not follow the wacom spec for the wintab interface. I will try to have a fix for this in the next build.
  • Bug
    @monsterfox I checked with other apps also (including Apple), and deleting and confirming a field always returns to the value before deletion. So I will keep this as it is for now.
  • Pixelated corners on panels
    @Ingolf said in Pixelated corners on panels: Issue introduced in 1.2 Yes, the themes changed in 1.2 a bit.
  • Alignment correction request
    @hbalcic Thanks! I will try to replicate this.
    @Boldline I will try to replicate and fix this.
  • Multiple repetitive panels
    @VectorStyler I remember this was a set of panels, four together, mixed, style, and I don't remember the other two. These multiple panels appeared automatically. This is the second time in two months. The specific situation is not very clear.
  • Settings not remembered between sessions
    Roger, thanks!
  • Strange (though useful) behaviour; is it a bug?
    @GRH there is also another way to get what you want using a Circle, there are parametric Shapes in VectorStyler which offers some options via the Shape Panel Menu > Panels > Shape Panel here a video
  • A problem with capitalization in Turkish
    @hbalcic Got it, thanks!
  • Keyboard shortcuts doesn't work with windows touch keyboard
    @Harry I could not replicate this issue with the Windows 11 touch keyboard. Can you upload a recording, maybe Im doing something different.
  • Weirdness with History, Locked States, Input Lock
    @debraspicher Thanks for the detailed description. Yes, there seems to be an error here with the Anchor tool. EDIT: got the documents by email. Thanks!
  • Redrawing of bitmaps while working with Pencil Tool
    @debraspicher I think what might happen here is a bit of panning. Even a small panning can have an large effect on zoomed-in bitmaps as the pixel sizes are large and jump.
  • Copy & Paste not working (intermittent)
    22
    34k Views
    @VectorStyler Let me know if there is anything extra I can do as far as monitoring...
