• Pen tool icon not always displayed
    @VectorStyler said in Pen tool icon not always displayed: @Ingolf Got it! And thanks for identifying the root cause, I will fix this ASAP. We'll it isn't - but toggling that state immidiately turns the pen icon on.
  • Blend tool - Bug when...
    @PatrickM yes, can be replicated. The blend is on a path (line) and that moves one of the ending. The node tool does not handle this moving correctly. Will be fixed ASAP.
  • Floating window - no way to move using the wacom digital pen
    @VectorStyler said in Floating window - no way to move using the pen tool: @PatrickM said in Floating window - no way to move using the pen tool: What is constant is that I don't see the initial handle before I release the mouse/pen (W10) Could be an issue with some settings? @VectorStyler Just to let you know it is fine with the v.066 and since I've deleted the settings.xml and workspace.xml files.
  • Recovery File not retaining original file name
  • The stroke window in the context panel/menu does not correspond...
    @VectorStyler file sent
  • Unable to draw gradient on hidden object - handtracing scenario
    And VS for comparison: [image: 1jZi9Pl.gif]
  • Immediate crash when opening any .vstyler file
    @Beardmancer I got the crash reports. It looks like it has problem reading the image stored in the file. Could you send me the file by email, or a link to it. (will be kept confidential, and removed after the issue is fixed). I will try to recover the file and identify the error. Is it crashing with other files?
    @Devil-Dinosaur said in The "select and transform members of grouped objects" option for the transform tool gives strange results when moving ungrouped objects: It happens to me from time to time. I thought I didn't set the child/parent link right in some options but it may be a bug. If you have an example where this could be replicated, please send it to me.
  • VS Freezes
    @Jayanta-Das Is there a file that could help replicating this issue? The problem is that there are no crash logs from freezes on Windows.
  • Scaling grouped text negatively affects font sizing
    @Boldline Yes, the font size is show (and edited) as if it is before the scaling. This is because the scaling is applied on top of this by the group. I added this to the backlog, to find a better way to show / edit the font size value.
  • VS freezing after unknown dialog
    @VectorWhiz said in VS freezing after unknown dialog: @Boldline Thanks for pointing this out, I will follow your advice. No problem. I have it set this way in the "new document setup" so it's activated for every new file I make. There are many upsides to having this active; namely being able to return to it later and make adjustments and for sharing issues with the developer. It does increase file size and after a long period of working on a complex job, it can slow down VS dramatically. It helps at that point to delete the history in the history panel and save the file to free up space.
  • Color curve editing problem
    VectorWhizV
    @VectorStyler I am on Windows 10. After following your suggestion the problem no longer appeared. Thanks very much!
  • No sense - I need glasses
    @VectorStyler it is easily done via the context panel (time for me to rest ) [image: 1666103909521-0b6cc5df-4295-4a79-85b8-908a08ca1fdd-image.png]
  • Sudden scroll jump of the document to its extremes
    @ncic Can you send me by email a vstyler document where this jumping occurs. I tried to replicate here, but did not succeed. email is csraba at vectorstyler.com
  • Color and palette panel removed
    @Ingolf Could not replicate it.
  • .62 Filled shapes with the pencil tool now affects my pen tool as well
    @Ingolf Added this to the backlog, but I;m not sure yet what is the solution here. The option is on by default now. But this option did affect the Pen tool also in previous builds.
  • Copy/Paste from AI broken ?
    @VectorStyler said in Copy/Paste from AI broken ?: @Igull This issue should be fixed in build 1.1.062 Copy from AI then pasting to VS now works, but, when pasting the copied object into VS, it seems to be contained within a clipping mask. If you 'object/expand clipped groups', then, while it does expand, it also outlines any strokes Perhaps I'm missing something here and someone can clarify if that is the intended result ? I would have assumed a simple and straight copy/paste ? Neil
  • Bizarre nudge behaviour
    @Dazmondo Could not replicate the group nudging. Could be some text frame link or object cloning issue. If you have a file where this can be replicated, please send it to me by email.
  • Font sizes in prefs
    @Ingolf This issue should be fixed in build 1.1.062
  • Blend, artefact when changing gradient shape
    34
    51k Views
    @PatrickM Send me the AI files. If they are too large for email, you can send share a dropbox link.
