• VectorStyler 1.2 beta
    Pinned Moved
    12 Votes
    17k Views
    @Victor-Vector said in VectorStyler 1.2 beta: Just so you know, this works 100% with my keyboard's left ALT but it is jittery on my keyboard's right ALT. Yes, there were some issues in working with the right ALT key on Windows. I will try to improve this.
  • Stretched side panels
    I haven't restarted VS as yet and the panels keep on expanding... These are the results: [image: 1778071646134-stretched-panels-02.jpg]
  • Typo error
    @William-Kansepa Will be fixed
  • Change Screen Mode does not work
    @VectorStyler said in Change Screen Mode does not work: Is this the "Single Document View" mode? this should be inactive if no document is open. This is happening when I have open documents.
  • Replacing linked image caused file size to balloon
    @William-Kansepa said in Replacing linked image caused file size to balloon: If you check in Links panel, the image is still linked not embedded. Yes, but a copy of the image is also in the file. I will check why this happens.
  • Transform pivot point regression
  • Regression when placing images
    This is now fixed in the latest update!
  • 1.2.075 Properties Panel resize problem
    @larsherold I opened a bug on this.
  • Round Corners Bug
    @William-Kansepa said in Round Corners Bug: Scale Corners option I added this to the features backlog, but I'm not sure yet how this can be done.
  • 测试中文版
    @朱升品 I added your email to the license server. Please restart VS.
  • Crash report after reopening VS
    @debraspicher said in Crash report after reopening VS: However, deleting the folder did the trick for me, thankfully. Yes, this might happen if VS cannot delete the previous crash log files. Manual deletion fixes this.
  • stacked Transform shape effects should be independent
    @VectorStyler Ah - I had been interpreting the order wrong - I thought it's built "base up". Yes, now it works and makes very much sense. @Devil-Dinosaur I downloaded your preset and now need to find out how to load it I was thinking about shape effects because this can then be wrapped into a Layer style, so there is some kind of workflow of "switch off layer effect visibility to draw -> turn on effect visibility to see" and keep everything live.
  • Crash when objects with Erase blend mode duplicated
    @jkwchui Can be replicate here also, will be fixed as soon as possible.
  • Shape Effects / Transform has no parameters
    shape effects transform
    @jkwchui I will fix this for the next build.
  • Odd text spacing in imported svg file
    Thank you for the fix.
  • Bounding box changes after flipping artwork
    @William-Kansepa I agree with this. Even if technologically it is working as intended, it's not as intuitive for the user visually.
  • CSV as Data Source does not accept " " escaping
    @jkwchui Seems to be a bug, I will try to fix it for the next build.
  • Guidelines, dragging into Artboard group doesn't work.
    @larsherold Yes, can be replicated here also. I think this was the same before 032 also
  • VS sometimes fails to interpret text in a pdf file
    @William-Kansepa I did not yet receive the file. But from the image it seems that some ligatures (in this case "fi") are not translated back to glyphs.
