    3. Resolved 1.2 bugs
    • LoginErrorL
      Using a Global Color as the ending color in a stroke gradient turns it white
      Paragraph style - problem with History
    • RaaskotR
      Still annoying problems with exported pdf's
    • LoginErrorL
      Render as Image creates graphical artifacts
      Text decoration - overline
      Text Frame Option - Baseline
      half-tone bitmap distortion
      Or you test it yourself, use the AI software to copy a half-hanged net to VS and try.
      Toolbox items without icon
      Than I think it would help to block the possibility in the configuration menu to go this deep. so users cannot make this mistake and there's no confusion about it. Although this does not solve the other issue; that also single level folders don't have a default item selected and show no icon until you first select one tool inside. I would expect that there's always an item selected, also after firstly adding this group.
      Artboard name issue. Looks like gibberish
      @VectorStyler I changed the Artboard Label font as suggested, and it worked. By the way, I'm using a M1 Silicon Mac with Ventura 13.6.3. Thank you!
      Missing commands in appearance panel
      @Harry I will update the documentation (there are other changes also).
    • RaaskotR
      Viewport often blinks oddly
      @Raaskot Got it!
    • encartE
      Splitting text into lines is impossible
      @encart For some reason the MSI installer kept the previous language file. I will try to find out why this happens.
    • michaelokrajM
      Converting text to curves …
      @VectorStyler said in Converting text to curves …: The content of a text frame is not converted to curves with the "Convert to Curves" command. This makes sense - I'm not usually using the text frame method so I can see why I never ran into this problem prior.
      Artboard Becomes Bigger in PDF Export
      @VectorStyler Thanks, I didn't know we had to change the option.
      There is an issue when using Blended Shape to create a Repeater
      @VectorStyler Both have been fixed. Thanks.
      There is the issue exporting linked EPS format to PDF
      @VectorStyler fixed. thanks
      Moving a group with a displacement effect to the back causes a crash
    • Devil DinosaurD
      Problems with text in layers panel
      Devil DinosaurD
      Works fine on 1.2.018 Thank you for the quick fix
      Update to 1.2 DELETES ALL PRESETS without any warning.
      @MajorTom said in Update to 1.2 DELETES ALL PRESETS without any warning.: is there another folder with prestes? Yes, the local user presets are stored in ~/Library/Application Support/NumericPath/VectorStyler... folder You will find separate folders for 1.1 and 1.2
    • LoginErrorL
      On windows "Isolate Group in Layers Panel" and "Add / Remove Selection in Lists" both use the modifier key of Control.
      @LoginError said in On windows "Isolate Group in Layers Panel" and "Add / Remove Selection in Lists" both use the modifier key of Control.: This makes it isolate any object I'm trying to add to my selection Yes, there is a bit of a shortage of modifier keys. I will try to find better defaults.
