    • debraspicherD
      Is it normal to be able to open more than one Layers panel?
      @debraspicher The extra panel can be opened from the Layers panel menu, It can also be opened from the Canvas panel by clicking on the icon in a canvas row.
    • debraspicherD
      How to use these by keyboard?
      @debraspicher Should work when a node is selected. But now it seems that on Windows it is in conflict with a zoom shortcut. I will redefine these in the next build (fix the conflict).
    • ZATOPEKZ
      gradient for brush stroke disappear
      ZATOPEKZ
      @VectorStyler merci pour l'information
      Older versions are also showing in Installed app list
      @Jayanta-Das Remove those. There have been (and still are) some issues with the MSI installer. I will try to find a solution for this.
    • debraspicherD
      Issues working with Pattern Brush and Bitmaps
      Here is a larger version of the brush resource if it may be helpful for the purposes of internal testing: @2x grass resource
      Dxf import
      @Steve-Haley said in Dxf import: was led to believe that this version could directly import DXF files. There is no DXF support yet, and none mentioned in the documentation or website. DXF support is planned for version 1.3
      Does Vectorstyler support switching brush and/or color by switching to another physical Wacom pen? (Tool ID)
      Thanks for the info everyone. Just to clarify; I really would like to use this to switch brushes (in several software) (so not only to have having different settings like sensitivity curves in Wacom). Looks like this Tool ID feature to switch brushes is already possible with Wacom since 2017!! And at least available in software since 5 years ago (!) as seen in this video by Aaron Rutten of 5 years ago where he literally does switch two wacom pens to switch brushes and talks about this in the video below: youtube video
      Enhancing Workflow Efficiency in VectorStyler
      @jammessbol However, I sometimes find myself spending too much time on certain repetitive tasks. What kind of repetitive tasks? Some examples might help to find a good answer.
      Accidentally changing a value in an input field
      @Subpath Got it. this occurs if highlighting in a field that did not have the focus. I will try to find a solution for this.
      Outline Preview auto-converts artboard to black and white - what if I want it to stay color?
      @Boldline Not currently. The outline preview will render white outboard. This can be added as an option to show the color.
      Rotation angle resets to default when command-zero is used to zoom out fully
      @Boldline This is be easy to fix, but it will then change default behavior. Currently this is by design (default for zoom, pan and rotation). I will add an other action (maybe set to Command-0 by default) that only resets the zoom and panning to fit into screen
      How to use this tool?
      @monsterfox That tool should not be listed among the actions (something internal). The correct simplify path tool is in the toolbox (3rd tool group).
    • Y
      Questions about Puppet Warp tool
      @Yaoif Yes, it is called Elastic Warp. Can be added as a shape effect and then edited (similar editing as in Illustrator).
    • ZATOPEKZ
      Good brush parameters for non loosing color after one stroke ?
      ZATOPEKZ
    • ZATOPEKZ
      compatilities betwen AFFINITYDESIGNER brush and VECTORSTYLER brush ?
      ZATOPEKZ
      thanks for this information
    • RaaskotR
      How do I make copy/paste overwrite text work?
      @Raaskot I opened a bug in this, will get back soon.
      Best way to achieve this effect?
      @VectorStyler and @Subpath, Thanks! I will try.
      Stutter
      @monsterfox I will try to find a solution for this.
      Using Path eraser to divide a shape does not want to completely disconnect/ungroup the newly detached piece
      @Boldline yes, this seems to be an error.
      Adjustment layer halftone affects more than just the artboard
      @Boldline It will render the whole visible (or exported) area. This is basically the whole layer, the artboards are just guides for printing / exporting (Same goes with any other drawing). Adjustment effects can be restricted to an area or any shape, by drawing an object, adding the effect ti the object (as a regular image effect) and turning the object into an adjustment layer (in Object Options)
