• Pasting text should update Recent Fonts- what are the parameters?
    @Boldline It should be added when pasting the text. But only a single font is added, in case of multi-font formatted text. Send me a file that contains font that is not added when pasted.
  • Is there a way to hide the bounding box temporarily?
    @debraspicher said in Is there a way to hide the bounding box temporarily?: Sometimes the bounding box displays on the secondary view(s), sometimes it doesn't. Each document view should have its own separate selection. So the secondary view should not display a bounding box, if it has no selection. I will try to replicate this, as it seems to be a bug.
  • Canva Reference usability?
    @VectorStyler Yes, I did this but it also works by selecting all the symbols in once & CtrlX-CtrlV.
  • Layer selection tool use clarification
    @debraspicher The default Layers panel selection in VS is similar to the one in Illustrator. But in VS you can configure in the Layers panel menu -> Panel Options to sync the on canvas and Layers panel selection by checking "Select Highlighted" and "Highlight Selected" options.
  • Unable to select and move the symbol
    @Raaskot "Symbol 1" cannot be moved (replicated here also). This is caused by having Layers inside the symbol (only groups and objects are supported). The only way to solve this now is to remake the symbol with groups and objects (no layers in the symbol). I will try to fix this issue in the next build. "Symbol 2" can be moved here
  • I want to place layer in root. Not possible?
    @VectorStyler Good idea, thanks
  • Can't place cusp node on path
    @Raaskot A solved-note for myself and the audience. Be aware to choose mode of line segment. Then it works [image: 1717074906230-d84d446a-b688-413e-b426-4b426483d4a3-billede.png]
  • How do I turn off stroke scaling for objects pasted into a VS document?
    @Boldline you're welcome, I'm glad it was helpful perhaps it's possible to create an Action out of it? I agree, it's a bit hidden
    @Boldline Were these panels docked or floating? It seems that the workspace file resets for some reason (it does that for some key presses at startup)
  • Snapping seems different when using shift and option/alt
    @VectorStyler one thing I like in Affinity is that an obvious indicator appears when the selected shape is completely snapped flush with the first shape. In this example screenshot below, the three squares to the right side of the green line were dragged over to touch the original three squares on the left side. When they touched, an obvious green line appeared to let the user know they were exactly flush Here is a gif of what I am talking about [image: 1716830613706-cdb149a5-1ab8-40ad-9c2c-40e0053635b2-cleanshot-2024-05-27-at-13.21.34.png]
  • Saving Text Styles
    @VectorStyler Thank you for this feature. Works well in the latest 12.025 update.
  • Does the style picker not reference from locked items?
    @Boldline This could be a bug. I will try to replicate it.
  • about the movement distance
    @VectorStyler Or add a unit and let the user choose one, which would be better.
  • Transformed Clipping Shape distorts clipped content
    @VectorStyler thank you. This method is perfect!
    @Boldline said in How do I use the Split Object Shape - "inside split schemes" and "cut split schemes"?: If I understand it correctly, the divide can be created with an open-ended path or the interior of a fill? Yes. In case of open-path the object will be split along the path. Is this the way it's supposed to work? Yes, for a single shape this is the result, it cuts the part inside the star. I think the repeater can also be used to create a grid of shapes for a "split scheme", but regular duplication and grouping will also do.
  • Object with spot colors disappears/change in pdf-output
    @Raaskot It seems to be that Acrobat can open the resulting file but other apps have problems. I will try to find a solution for this before the next build.
  • Monospaced numbers, how?
    @Raaskot Solved it on my own Choose Tabular Figures under "Character Options/Typography/OpenType" [image: 1715942094345-79e66020-d3ca-4d54-9588-e4c10b821c06-billede-resized.png]
  • Confusing style-editing in VS
    @Raaskot Seems to be a bug. Removing the default character styles causes this. The fix is to set a color for the text (it is missing). I will fix this ASAP.
  • Question regarding floating panel behavior when using other applications
    @VectorStyler I'm probably just not used to it. I'd have to spend more time with it on daily tasks to know for sure, but other than it being different, so far I'm not inclined to say it needs a Preference option. Users who prefers to spread panels across displays likely benefit most from the behavior. Whereas in my case, it's just a matter of being able to read items while staring at another application, which I can do simply by clicking the window active. It's no biggie.
