• compatilities betwen AFFINITYDESIGNER brush and VECTORSTYLER brush ?
    ZATOPEKZ
    thanks for this information
  • How do I make copy/paste overwrite text work?
    @Raaskot I opened a bug in this, will get back soon.
  • Best way to achieve this effect?
    @VectorStyler and @Subpath, Thanks! I will try.
  • Stutter
    @monsterfox I will try to find a solution for this.
    @Boldline yes, this seems to be an error.
  • Adjustment layer halftone affects more than just the artboard
    @Boldline It will render the whole visible (or exported) area. This is basically the whole layer, the artboards are just guides for printing / exporting (Same goes with any other drawing). Adjustment effects can be restricted to an area or any shape, by drawing an object, adding the effect ti the object (as a regular image effect) and turning the object into an adjustment layer (in Object Options)
  • How do I reset the settings of the eraser panel back to the default?
    @Boldline said in How do I reset the settings of the eraser panel back to the default?: It would make more sense if "default was listed instead of it always saying "custom". I will try to change this.
  • How to use the Settings linked files
    @VectorStyler ok I think I understand. The file gets stored here "behind the scenes" but we look for the custom settings found inside the folder(s) where we adjust the settings file and workspace drop down buttons in the context panel. makes sense now - thank you
  • 360° Conical and Spiral gradient
    @nocturnalYL There is a bug here, I will have it fixed by the next build and then it will be possible to have asymmetric color
  • Resources Panel?
    @VectorStyler It appears when AltGR + Z combination is pressed in my case. I'm using polish layout.
  • Polygon tool - where?
    @jsampson45 your welcome No matter what is showing here this is the "Smart Shapes" Section i.e they could be further be editied via the Shape Panel The currently selected Shape will be displayed at the bar. Note this little Triangle on right here which always mean there are some more Tools [image: 1721907071928-triangle.png]
  • "Open Recent" list empty after updating to newest build
    @VectorStyler Yes - after I opened a file I had used previously and then saved the updates to it and then closed it and restarted VS, it now shows in the "Open Recent" - but none of the other files listed prior to the update are there [image: 1721745840095-9a63d567-a36b-4b8b-8f41-dfdf492d50d3-bld-2024-07-23-at-10.41.46.png]
  • Save multiple effects (as a style?) and apply them to an object
    @Pat said in Save multiple effects (as a style?) and apply them to an object: Object Style can be created using the (+) button in the Styles panel, that opens a style kind selection menu Please send a file with the object that causes this crash (there must be an object to create a style).
  • Export to .PSD
    @Kemelvor Moho looks cool, seems also that it have an impressive Feature Set
  • Memory loss
    @Ayo Yes, the cause is the number of nodes (not available as a setting). I will try to find some solution to show some nodes even for these cases.
    @Boldline said in VS does not currently update live text font when grouped when missing font is activated externally: Basically - is it possible to have VS update missing fonts despite it being grouped? Grouping should not affect this. I will try to replicate this issue, it could be a regression.
  • Inconsistent Polygon Rotation Angle
    @_NM_ said in Inconsistent Polygon Rotation Angle: a 5-sided Super Shape appears at a 180 degree rotation relative to a pentagon drawn with the Polygon tool. I will loom into this, and fix it if possible.
  • Deactivate preset folder but keep it in sight?
    @Ayo said in Deactivate preset folder but keep it in sight?: Button 'Export Group' in the Preset Manager means export the whole group of all the presets This should export only the types in the current group. I will open a bug on this to verify it.
  • Save Palette > Vectorstyler Default format
    @Ingolf A split to Save (without formats) and Export (with formats) sounds very clear and helpful
  • It is HSL not HLS
    HSL it is now, many thanks!
