    @VectorStyler said in How best to handle gradients when exporting from VS to a different vector program: @Boldline Send me the VS file by email and I will try to replicate this issue. Could be a gradient exporting bug. When you are ready, if you need me to test an exported file in my version of Illustrator CS6, I'm happy to do that. just email it over and I'll let you know how it goes
  • Artboard Guidelines only visible on first row artboards
    @Harry said in Artboard Guidelines only visible on first row artboards: then every artboard should have the same guidelines in the same spot A fix for this bug will be in the next build.
  • Does VS need to record the computer's screen and audio?
    C
    @VectorStyler Great!
  • Tracing a png file
    @Pat In the Image Trace panel menu there is an "Ignore White" and "Ignore Transparent", enabled both (these are disabled for the Photographic preset).
  • Uniform stroke scaling
    @VectorStyler Yes, I know & it is also fine but since it is tied to "Transform stroke", it would be logical IMHO to have it directly in the panel beside "TS" (no need then to check in the panel menu).
  • No response when changing font specifications
    @Raaskot Found the error. It was the Cmd+A that I missed. I will fix this ASAP. Meanwhile as a workaround, for changing the font of the whole text, just select it with the transform tool.
  • Object snapping without visible hairline?
    @creative said in Object snapping without visible hairline?: @VectorStyler Is there something like "align to pixel grid" like in Illustrator? "Align to Pixel" in the Transform panel menu. But it is a non-destructive operation, so it can be removed by unchecking.
  • How. would I create this pattern in VS?
    @Boldline your welcome looks good
  • Using templates?
    C
    The last destination ist displayed. If the document is saved to a folder "my documents" next time using "New from Template" isn't showing the "templates folder" to chose a template but the last used folder "my documents".
  • Resolution and appearance?
    C
    @VectorStyler The system only shows me "2560 x 1440 (QHD/WQHD - Wide Quad High Definition" but the display's data sheet shows 92 ppi. Now I have 2 documents with 2560x1440 and a square 500x500 px in it, one with 72 dpi and the other with 92 dpi. With both dpi values the display fits 100% in VectorStyler and also directly on the Mac with both resolutions if you export the document as jpg and display it as actual size and full screen, at 72 and 92 dpi surprisingly.
  • Shape effects
    @VectorStyler @Subpath As @Subpath showed, contour can work. Also using multiple strokes with different alignment values (set alignment to absolute value). This should work. Thanks Concentric shape tool is another option for circles.
  • How to configure this bar?
    @VectorStyler said in How to configure this bar?: @maarten It is just like the toolbox Yes, I had found it and have configured it. Thanks for your confirmation
    @VectorStyler Thanks - the "X" icon is what I was looking for. The simplest things are most often the hardest to find
  • Applying Paragraph Presets
    @Kumr I opened a bug on this and will try to replicate it.
  • How can I edit the size of rotated text box?
    @Raaskot The text box seems to have 2 transformations. The Shape Effects panel contains these transformations and can be individually removed there also.
  • How to restore the default settings for keyboard shortcuts
    Yes, that would be nice. Thank you.
    @Boldline said in Live text that is modified and copied and then pasted over text on path does not retain edits: would I need to alter it in the appearance panel instead? I think this this case you need to use a character scaling option from the Character Panel (expanded mode of the panel). Also, there is a Settings that changes the character scaling when scaled with the Transform tool.
  • Coordinates top-down direction as default?
    @creative When you create a new document with the "New Document Setup", all the settings changed there will be defaults. There is a "More Options" button on the right side, if you scroll down.
  • Creating and using guideline groups?
    C
    @VectorStyler said in Creating and using guideline groups?: I think what is needed here is document templates. Just set up a new document with guidelines and everything else needed, and then save it and use it as a template with the New Document Setup. Thank you very much, that's probably the best way. With so many great features and functions in VectorStyler, it's easy to lose track.
  • Document presets backup?
    C
    Mac, I looked at the reveal workspace but include those files there the dozens of new document presets I created? The Presets Manager seems to be the better way.
