• Options in Snapping Panel. (Windows)
    @Gremriel Got it. Thanks! The bug also occurs on Mac.
  • Preview Shape Combine (Document Editor option)
    @Gremriel Looks like an error. Will be fixed in the next build. Posting is welcome this is how the app gets improved.
  • Regarding Guidelines
    @Gremriel Yep, got it replicated. Problem occurs after multiple documents are opened, and switched between.
  • Text on Path: how to make the text centered?
    Thank you.
  • Mysterious guide
    @vectoradmin Nice!
  • Text on Path: what is happening here?
    @Gremriel The selected text outline issue is fixed in build 1.0.025. Let me know if there are other issues.
  • Info panel with object (segment, node, etc.) information?
    @Arde Yes, that is the document info, and it does not show info on objects. I think a separate object info panel (with position, size, colors, and maybe shape length / area) could be added at some point. I will add this to the new features backlog, it might not make it into version 1.
  • "Japanese vertical type" 2
    @861475_VctSt Let me know what are the issues
  • Origin of artboard
    @vectoradmin I confirmed the correction.
  • What does isolation mode of single element do?
    It's like the mask workflow in FreeHand, instead of using clipping masks a shape can be masked by copying it and using "Paste Inside" in a parent object. Then once you double click the parent object and enter isolation mode you are able to edit the contents you just pasted in. You can also repeat the process on the children objects and paste things inside of those to create masks inside of masks. It confused me too at first because i wasn't expecting it and the relevant UI was pointing me towards something like Illustrator but It's much faster and intuitive method than clipping masks, trust me on this.
  • Is there a way to specify overprint attribute for a color?
    @vectoradmin said in Is there a way to specify overprint attribute for a color?: This can be done in the Styles -> Overprint Options -> menus. Ok, thanks. Did not quite follow but I'll try to figure out how this combines with the separations printing!
    @vectoradmin said in Is there a way to flatten blend groups and similar controlled constructions?: The new build adds a separate "Position" function to the blend object transfer curve options. This will control the position of the inner objects. Brilliant! It is very rewarding to give feedback when suggestions and reported bugs are clearly noted and reach immediately developers!
  • Possible release date?
    @vectoradmin ok I'll try to do more with those areas you highlighted, you know you can count on me to give you the older el capitan reports!
    @vectoradmin I checked the "color profile" display. A small but very useful feature for us. Thanks
  • Convert path/curve to text frame?
    @b77 I will look more into how to merge these two tools.
  • What is "stroke"> [fill] ..... ??
    @vectoradmin Completely remove VS (by AppCleaner) Not an overwrite update, I reinstalled it. As a result, it was fixed. Thanks It's getting more and more comfortable.
  • Patterns
    syllieS
    @vectoradmin said in Patterns: For now the outline can be selected in the panel, by changing the panel state with the up-down arrow before the panel title label. This rotates over several panel modes, the second mode contains the outline and background setting. Ah! I know about the states, just didnt think to check it here! Thanks. All the other feedback makes sense too!
  • Anyway to dynamically change the 'brush' size?
    19k Views
    Seems to be working with the pencil and brush now on the Mac also.
  • Logic behind node controls
    @grix An explanation of how nodes work in VS: There are two concepts to define first: the node is a point location. the segment goes between two nodes. The type of a node can be cusp, smooth or symmetric. This affects how the curve changes when the node is edited. Changing the node type from smooth (or symmetric) to cusp will not have a visible effect, since the two control points (on the two sides of the node) are not changed. The node type is only visible when the control points are moved. In cusp nodes the two control points around the node can be moved independently of each other. In smooth nodes, the distance of the two control points from the node is idependent, but the direction along the same line (creating a smooth curvature). In symmetric nodes, both the distance and the direction are constrained. (Most apps don't implement symmetric nodes, except CorelDraw). The type of a segment can be line, quadratic and cubic. Typically we have lines and cubic curves. VS includes quadratic also, these are the curve types used in TTF font glyphs, and also required for SVG. The difference between quadratic and cubic is the number of control points (and degree of freedom) on the curve. Most apps don't have the quadratic mode. The change that you were looking for (removing the control points) can be found in the Path panel, with the first two icons in the third row. These change the node type to cusp, and move the incoming / outgoing control point over to the node location.
