  • Can we make strokes more directly selectable?
  • Add shift modifier to magic wand to select multiple types of objects
    @Boldline This should be available in build 1.1.024
  • Path panel option to retract both handles of any selected nodes
    @Boldline Clicking on the Cusp node button again, should retract both handles.
  • Could we add the ability to group guides?
    @Boldline Why not use "guide" objects for this. Draw several lines, group them, and turn them into guides with View -> Guides -> Make Guides.
    @vectoradmin I commonly used the AI version of workspaces to clean up the screen of floating panels. I was much more willing to detach panels and move them around as I worked ignoring I could at any point click a button and reset the workspace arrangement. Right now in VS, it takes some effort to get the main panels I use in the best configuration and I'm hesitant to drag out a panel because it means having to manually add them back in. There are also panels I don't use as much as I want to because I have to go find them, open it and arrange them each time. It's laziness on my party for sure but it's also repetitive and not efficient Thinking of new users, they may not even know what all panels are available for a certain task. Setting up defaults based on common tasks would give them a head start. I also look at swappable workspaces like an extension of the contextual menu bar. Between the customized workspace and the contextual menu bar, so many options are opened up to the user
  • Contextual Mouse/Key Tool Mod Help at the bottom of the screen
    @Victor-Vector There is a related feature request for an "Info / Status" bar, I added this also.
  • Hand tracing features (3/3) - Panel
    I was looking at the online Illustrator user manual and found this list of panel arrangement position options. This conversation thread aside, I've been requesting panel workspace defaults and the ability to create custom workspace layouts anyway, but @Ingolf, one of the optional layouts is geared toward tracing. [image: 1647703225369-c87324c3-45a3-48ef-a17d-10ff8047149d-bld-2022-03-19-at-11.14.49-resized.png]
  • Hand tracing features (1/3) - Reference layers/objects
    19k Views
    @Ingolf I think @b77 had a great answer in his post here an hour back. See how far you can go with actions and also what kind of custom panel arrangement would suit you and share that in the forum. Before we can fix a problem, some of us would need to see clearly the problem itself
  • Hand tracing features (2/3) -
    @vectoradmin said in Hand tracing features (2/3) -: @Ingolf said in Hand tracing features (2/3) -: Find Edges I guess OK. But then blur will smooth the found edges out. Yep - intended. The find edges makes some very rough edges on photos.
  • Three user stories for hand tracing features
    @Ingolf Thanks!
  • Freeform Gradient
    @Jayanta-Das Maybe further down the road
  • Incremental input option for vertices count in Star panel
    @Devil-Dinosaur When pressing the up/down arrow button with the mouse it does open the slider, that is by design. I was referring to pressing up/down arrow keys on the keyboard. The editors where the up/down arrow buttons work as scroll buttons are a bit different: Vertices field has a popup slider. Level field has an up/down arrow for scrolling. I will try to find a way to have both of these options, the problem is that I have not yet found a good design, and adding two buttons to each field is not the way to go.
  • Idea, to maybe extend the Forum a little ?
    @Boldline Haha, I am here for all the reasons you described! I look forward to learning enough about VectorStyler to be able to fully integrate it into my graphic design production pipeline. Thanks again!
  • Using 3D to create complex forms in VS
    @vectoradmin thanks - I understand that. I figured this was a version 2.0 feature. I just keep sharing things as I think of them and if they help me expand on an initial idea I already shared
  • Option to add strategic nodes to shape
    @vectoradmin said in Option to add strategic nodes to shape: adding a node at a center is possible by selecting one of the previous node and pressing the + key. OK this works for me, I had forgotten about this option! This is a simple solution that works and does not complicate things.
  • Image Tracing Preview
    @Boldline Ya the tracing is not so precise, may be it is because of the image type or may be because it is in alpha. What I am asking about was live tracing. And it seem there is some other option also for color tracing, but how precise I don't know.[image: 1646154874503-screenshot-2022-03-01-222438-resized.png]
  • Locking individual and sets of tool panels
    @Boldline Probably having the "workspace switching" would solve this, but workspace includes a lot more than panel states. Question: how would locked panels behave? Can they be moved? and can we cycle through various states by clicking the up/down arrow? Or would it be better to just have an easy way to capture / recall any collection of panels? [image: 1645466748757-cycle.png]
  • Spacing arrangement idea
    @b77 said in Spacing arrangement idea: Workspaces, or preset/custom UI configurations. In my mockup that would be a 'Typography' workspace, which let's say can display the Character/Paragraph panels in place of the Layers panel, and have the Layers panel be displayed on its own column, maybe paired with the 'Canvas and Artboards' panel. This ties in with a future addition request I had made about resetting the workspace to a default or designated arrangement similar to what is available in illustrator. Illustrator has a number of default layouts based on intended design use. There is also the option to create your own. I like the location of this option @b77's mockup and then it could potentially also be added to the view menu as we discussed in another recent thread
  • "Kill switch" option ideas
