  • User interface - adjusting panel height (when docked)
    @Pat I will try to improve this. If the other docked panel heights cannot be adjusted, then the color panel will have its maximum height.
  • Idea concerning "Hovering selection" while using selection tool
    @Ayo said in Idea concerning "Hovering selection" while using selection tool: Take your corporate color blue for example To seduce and feel old Freehanders coming home
  • Additional guide options while using pen tool
    @monsterfox Yes it's in development. I first found it about a year ago and it was at a very very basic level, but I was intrigued by it and would occasionally check in to see how it was doing. I hadn't checked in since spring of this year and found they had done a lot of work on it over the summer months. One aspect that intrigued me was the ability to switch around attributes of each shape. It might be an interesting thing to add in VS at some point. [image: 1729524879261-22f8ee42-c5d9-4a1c-a8e0-5a44a2fe78a3-bld-2024-10-21-at-11.33.26-resized.png]
  • Moving object or center, delay as progress
    @monsterfox said in Moving object or center, delay as progress: The display speed of Illustrator is faster. Can it be made the same? I will try to improve this.
  • Advanced Design Tools: Streamline, Optimize, and Create!
    -2 Votes
    @vope said in Advanced Design Tools: Streamline, Optimize, and Create!: I think that besides the "Font Identifier / Retype" (which needs AI) all others are present in VS.
    @Boldline There seems to be an error here with the text resources.
  • Idea related to the Toolbox Flyout Menus
    I approve this message,
  • JPEG XL support
    @nocturnalYL I have this in the 1.3 backlog, I will try to implement it, subject to the availability of suitably licensed implementation.
  • Extend Windows menu buttons hotspot to the top
    @nocturnalYL I will try to improve this.
  • NEW UI
    @fde101 Everyone's work habits and the program interfaces they use are different. It's fine to find what suits you. You should be used to the interface of Illustrator software, while I'm used to the interfaces of FreeHand and CorelDRAW. I have been using them for more than ten years. It's very difficult to change this habit.
  • Consolidating smooth and symmetric options in a dropdown
    @Boldline I will try to find a solution for this.
  • Opening of Layer Menu Panel Auto Highlights Name
    @Boldline The name field supposed to be active after opening, but I think the highlight is not set by default. I added this to the backlog.
  • Alternative method to save recovery files?
    @Boldline There seems to be a regression here. The problem was identified and the fix will be in the next build.
  • ornamental stars
    @VectorStyler yes you are correct. I was expanding on the idea by sharing a few different stars that this could work with and could potentially be included, not just the standard five point star. No rush on my part to add these. I was just using them today in my work and it reminded me to share
  • Perfect symmetrical dotted lines
    @monsterfox I added this feature to the backlog for 1.3
  • Data Source for Artboard Naming
    @encart Data sources documentation is here: https://www.vectorstyler.com/documentation/symbols/datasources/ Related to this are number variables: https://www.vectorstyler.com/documentation/symbols/numbers/
  • Small Improvement to Panel Snapping
    @debraspicher I added this to the backlog.
  • Menu focus should follow cursor
    @debraspicher I will try to modify this.
  • Polar Grid Tool
    For VS, I was thinking more of a "concentric grid" parametric shape option to get a "polar grid/radar" type of graph
