  • Affinity Designer import
    7 Votes
    No, it's probably not simple, but perhaps this project could be of some help. I'm sure they've reverse-engineered it. I hope you can find a good lead. It's precisely a format shared by all three applications, so I hope the vectors are reasonably separate and identifiable. My big curiosity is whether it's a spaghetti format—or if it's well-designed.
  • Regarding the halftone repeater types
    76
    205k Views
    @VectorStyler Sorry, I've been a bit busy lately. I didn't explain clearly. I meant multiple blended shapes, not a single blended shape. I couldn't find the files I make on before. I'll redo them when I have some time and send them to you.
  • Help with Path Brush Tool
    @VectorStyler: Thanks a lot!
  • ruler editing
    @ZATOPEK This is in the backlog for 1.3 (later)
  • Thoughts on the Distortion Tools
    @VectorStyler said in Thoughts on the Distortion Tools: @Subpath I added this to the features backlog, and I will try to find a solution for 1.3 some distortion Tools into one Tool This last point is not clear Let's say you have 4 distortion tools that are most similar, e.g. in terms of settings. That these could perhaps be combined into one tool and the options of the 4 tools could then be accessed via a dropdown menu in this combined tool. This could reduce the number of distortion tools somewhat but keep the features of it. Just an Idea dont know if this makes sense.
  • Pucker tool like functionality.
    @Subpath @VectorStyler Thank you very much for the help. Needed this function for a project work. I can use both the circular and liquify brush settings shared here. I agree illustrator tools are very fluid over VS brushes, may to find the right settings and speed as you pointed out.
  • Pen Tool
    @monsterfox I add this to the backlog for the future.
  • calculate the centerline
    @monsterfox I will add this to the features backlog.
  • Select two open nodes to join automatically
    @Li-Xiao as I wrote before VectorStyler is the "Swiss Army knife of vector graphics"
  • Split Text changes alignment of text
    @VectorStyler Thank you.
  • Extending options in the Transform tool
    @Boldline Most of these additions will be for 1.3.
  • Separation of the stroke and the arrow
    @William-Kansepa your welcome Here is an example from me, I once had the idea that it could be useful for a circuit board like graphic design so i made me this custom Arrow Head [image: 1721205538458-circuit-boards.png]
    @VectorStyler said in Can the Bucket Fill Tool be improved by allowing it to create shapes based on negative space between paths?: I will add the fill/stroke in the next build. This will be a very helpful added function! thank you
  • Transforming tools need to be upgraded.
    @VectorStyler VS currently has several transformation tools that operate outside the selection box, and what is needed now is a tool that can operate within the selection box. Freehand and Ai both have tools that can be operated within it, and you can experience it.
    @Boldline I will add this to the features backlog for now. I will try to find a solution for these issues.
    @Boldline Should also be configurable in the Settings -> Modifiers section.
  • Just an Idea related to the Color Picker
    @VectorStyler I would say it is a very minor thing and I can live without it, don't want to overload VS, so let's stick with setting the stroke mode by now. This idea came to me from the way color fills are handled with the color wheel (fill and stroke fill). If you select colors from the color wheel, you can use the right mouse button for stroke fill without setting the stroke mode first. . . But I'm wondering what the right mouse menu is for when the color picker is active. I didn't understand the point of it. . . @Boldline ...Are you suggesting getting rid of the right-click menu... No, not really. See my answer to VS. But I was surprised about the right-click menu that you can call up when the color picker is active and I don't really understand its purpose.
  • Struggling with Snapping
    @Boldline Will be fixed soon!
  • Functional request
    @monsterfox Maybe in later versions (requires a bit of work), the problem is that there is no "persistent" selection of these nodes, they are selected only while the mouse is pressed. But you can adjust the distortion precisely using the Shape Effects panel.
