  • "Paste and Match Style" feature
    @Ayo Send me the file where this occurred. Could be there are are some other issues with the text (related with the earlier comment on pasting formatted text).
  • Select All Objects while working in the Node Tool
    26
    38k Views
    @Ayo Sometimes there are different paths to reach the destination. I just chose an additional route. As long as we reach the destination, wouldn't it be better if there's a faster method? For me, I prefer having multiple ways to achieve the same goal. In case one method encounters a bug, I can switch to another method. This is the best approach before the bug is fixed. Of course, everyone has their own way, as long as the goal is achieved. Thank you for your many suggestions. They will make VS even better.
  • Two alternatives for Break Shape
    @Ayo Added this to the backlog.
  • Option: Snap to point/shape text
    @Ayo Background Example usage. Point Text is an ideal text form to use in cartography. Compact and bendable too! In a typographic layer with a high density of text objects, you want to use text objects as snapable, but not the text (glyph shapes) itself. It is insecure in aligning symbols to text lines (no need to align to acender, x-height, O-height etc.) and also saves a lot of visual clutter caused by flickering indicators. [image: 1698586470222-7508690e-0572-46ae-b78d-a93cf1bf63c3-image.png]
    @Daviator Panels menu -> Color opens the floating color panel. In the floating color panel there is a color picker tool that can be used to pick colors from the drawing.
  • Two more tool requests inspired by Extend Path Tool
    @Ayo Indeed, it's a long list of new features and improvements.
  • Grid-It Extension
    @VectorStyler said in Grid-It Extension: creating handles: this seems to add lines and circles where the curve handles are. This could be implemented easily, but not clear what is the use case. creating outlines: not clear what is new in this case, it seems to add an outline to the object. These two are similar to Mark Fromberg's Presenter plugin for Glyphs. They are just like a (vector) visual effect, to make things look interesting. @Boldline To me the grid/guidelines part seems to be the most useful, and can partly be emulated in VS, as the developer said.
  • Cool ideas to add to the guides in VS
    @Boldline said in Cool ideas to add to the guides in VS: The ability to cut a selected guide with the knife tool and then delete one selected section of it or the other The ability to trim guides to the artboard by adding the guides while the artboard itself is selected The problem in case of VS with this is that guidelines are not part of the graphics (layer) hierarchy. They are just "guides". But it is possible to turn objects into guides, in which case the knife / trim tools will work
  • Pull nodes in opposite directions
    @Boldline Yes, same steps in VS, hold Control when scaling the selected nodes: https://recordit.co/zMmUz83C3H
  • Requests for paper size set in VS
    @VectorStyler Thanks Implemented in ver 1.2.001 beta.
  • Alt-click new layer automatically adds selection to that new layer
    @VectorStyler Nice!
    @encart Added to the backlog.
  • Color Picker with magnifier working also outside VS
    @Harry working also outside VS Technically this is doable, but when doing this MacOS will (and should) notify the user if it allows VS to record the screen. And the user must add VS to that allowed list somewhere in the security settings.
  • Making saved points in the history more visually prominent
  • Could/Should items be automatically grouped when placed into VS?
    @VectorStyler said in Could/Should items be automatically grouped when placed into VS?: @Boldline Are these vectors grouped in the other program? Here a few tries from me VS to Affinity Designer 1, no Affinity Designer 1 to VS, yes Clip Studio Paint Vector Layer as SVG to VS, yes VS to Clipstudio Paint as SVG Vector Layer, no Corel Draw to Affinity Designer, yes Corel Draw to VS, yes
    @Boldline I was referring to Pencil 's and Brush Tool 's options in the upper toolbar to add them to Path Brush Tool toolbar also: [image: 1693399043614-obraz_2023-08-30_143722144-resized.png]
  • Tint option in the Color / Palette panel
    @William-Kansepa said in Tint option in the Color / Palette panel: It could be user error on my part, but I can't seem to find the option of changing the tint of a swatch. I notice that there is a different kind of Tint option under Variations, but the one I am looking for should be be under the Color or Swatch panels. What I see is only the Opacity slider. For the purpose of clarity, I will use these screenshots of Affinity Designer as an example. [image: 1693146062162-affinity-designer-colour-options.jpg] [image: 1693146133471-affinity-designer-tint-amp-opacity-sliders.jpg] I found the Tints slider at the bottom of the Colour palette after expanding the palette!
  • Expanding the options for the Path Sketch Tool
    21
    38k Views
    @pentool said in Expanding the options for the Path Sketch Tool: A little off topic, but the reason I don't like those screen recorders is because they don't scale. If you have a big screen, it won't fit into a 13" laptop screen and have to scroll left/right/up/down sometimes to see what people are doing. Yes, your right a youtube video could be a better choice if you need a full screen record. But often you need just a little area and its fast and it get the job done. (ScreenToGif is a 170 kB Tool ) On window you could scale the contend of a browser a bit via Control Key and the scroll wheel.
  • Option to remember fonts recently used in document/most recent
    @Boldline I think this has been requested before, a sort of document specific favorite fonts, but it is marked manually. This will be in 1.2
