  • Preview option for shape tools
    @Kumr Should be possible to add. There is also the Shape panel that contains a bit more options than the context panel. I added this to the backlog.
  • Standard paragraph presets
    @VectorStyler The idea is to help on boarders and for someone would like to do a quick mockup work. Some basic styles, presets, etc, which ever possible so one can kick start their work for eg, the bullet list in the above screenshot.
  • Misleading
    @VectorStyler said in Misleading: The main issue that the "dual" character / paragraph leading thing will stay in some form. Why? As long as it's invisible, it's ok for me
  • Preview Text Frame indicator in Node Tool mode
    @Ayo Thanks for reporting this. It is added to the backlog.
  • Block Shadow effect tool
    @VectorStyler Got the email. Thanks.
  • Alternatives for 'drawing place' icons
    @Harry Thank you. You're right, that association also occurred to me. Now I have placed the pencil a little further away (as far as possible because space is limited in a square) and more away from pointing towards the center of the circle. Think that's better. Send an update of the file to Vectorstyler. [image: 1699610509871-4834800c-2c6a-4c80-9a49-26c37aef0524-image-resized.png]
  • "Paste and Match Style" feature
    @Ayo Send me the file where this occurred. Could be there are are some other issues with the text (related with the earlier comment on pasting formatted text).
  • Select All Objects while working in the Node Tool
    26
    38k Views
    @Ayo Sometimes there are different paths to reach the destination. I just chose an additional route. As long as we reach the destination, wouldn't it be better if there's a faster method? For me, I prefer having multiple ways to achieve the same goal. In case one method encounters a bug, I can switch to another method. This is the best approach before the bug is fixed. Of course, everyone has their own way, as long as the goal is achieved. Thank you for your many suggestions. They will make VS even better.
  • Two alternatives for Break Shape
    @Ayo Added this to the backlog.
  • Option: Snap to point/shape text
    @Ayo Background Example usage. Point Text is an ideal text form to use in cartography. Compact and bendable too! In a typographic layer with a high density of text objects, you want to use text objects as snapable, but not the text (glyph shapes) itself. It is insecure in aligning symbols to text lines (no need to align to acender, x-height, O-height etc.) and also saves a lot of visual clutter caused by flickering indicators. [image: 1698586470222-7508690e-0572-46ae-b78d-a93cf1bf63c3-image.png]
    @Daviator Panels menu -> Color opens the floating color panel. In the floating color panel there is a color picker tool that can be used to pick colors from the drawing.
  • Two more tool requests inspired by Extend Path Tool
    @Ayo Indeed, it's a long list of new features and improvements.
  • Grid-It Extension
    @VectorStyler said in Grid-It Extension: creating handles: this seems to add lines and circles where the curve handles are. This could be implemented easily, but not clear what is the use case. creating outlines: not clear what is new in this case, it seems to add an outline to the object. These two are similar to Mark Fromberg's Presenter plugin for Glyphs. They are just like a (vector) visual effect, to make things look interesting. @Boldline To me the grid/guidelines part seems to be the most useful, and can partly be emulated in VS, as the developer said.
  • Cool ideas to add to the guides in VS
    @Boldline said in Cool ideas to add to the guides in VS: The ability to cut a selected guide with the knife tool and then delete one selected section of it or the other The ability to trim guides to the artboard by adding the guides while the artboard itself is selected The problem in case of VS with this is that guidelines are not part of the graphics (layer) hierarchy. They are just "guides". But it is possible to turn objects into guides, in which case the knife / trim tools will work
  • Pull nodes in opposite directions
    @Boldline Yes, same steps in VS, hold Control when scaling the selected nodes: https://recordit.co/zMmUz83C3H
  • Requests for paper size set in VS
    @VectorStyler Thanks Implemented in ver 1.2.001 beta.
  • Alt-click new layer automatically adds selection to that new layer
    @VectorStyler Nice!
    @encart Added to the backlog.
  • Color Picker with magnifier working also outside VS
    @Harry working also outside VS Technically this is doable, but when doing this MacOS will (and should) notify the user if it allows VS to record the screen. And the user must add VS to that allowed list somewhere in the security settings.
