  • Simply Group or Clipping Group?
    @VectorStyler Clipping groups are shown now with the proper name in the Layers panel.
    @Boldline This issue should be fixed in build 1.1.062
  • Usability: smoother workflow (layers panel, selection)
    @Ingolf Use the Preferences -> Changing Options -> Select After Delete option, in the new build 1.1.062
  • Global Swatch marker
    @William-Kansepa I postponed this feature request. The main issue is that changing the background to a fixed color would not help for colors that are too close to that fixed color. I will have to find a better solution for this.
  • The Swatches Palette issues
    @William-Kansepa Replace colors when creating Global / Spot palette colors should be fixed in build 1.1.062 EDIT: part two, color merge is also available now.
  • Align via glyphs
    @encart Yes, this works for text shapes. But for text frames, the alignment will be to the frame, not the glyph content.
  • Perspective tool
    21k Views
    @Dazmondo In my post above I wrote that Copy and Past is only possible from ClipStudioPaint to VectorStyler. Need to correct that. Found an option in VS Preferences > Performance > Copy as SVG If you set this Option, then it is also possible to copy Vector Objects from VS to CSP. But only lines, because CSP has no vector fill also lines profiles from VS do not work. Here an example of copying from VS to CSP VS [image: 1665561258100-bildschirminhalt-erfassen-1.png] CSP [image: 1665561266998-bildschirminhalt-erfassen-2.png]
  • Close curve feedback (inspiration)
    18k Views
    Wouldn't hurt to have a similar indicator when the transform pivot snaps to one of the corners of a shape/bounding box when moving it, and also when you move it back to the center. https://recordit.co/kSOI8CFqB0
  • The context panel – possible improvements
    I agree with predefined workspaces/setup themes, I'm used to that from Corel Draw. Always had my custom defined workspace there. Corel Draw 2020 has these Workspaces Lite Standard Touch Specialty: illustration Page Layout Adobe illustrator just for inspiration Apart from that you could always create your own Workspace and name it where ever you want
  • Windows installation and update observations (minor)
    @Ingolf said in Windows installation and update observations (minor): One word: optional. thats true
  • Inspiration for Halftone patterns that could be built into Repeater
  • Offset Path GUI Change
    @Boldline said in Offset Path GUI Change: Maybe it needs to be a three choice dropdown? none- preview- low opacity Yes, I can understand the functionality wanted from an artistic standpoint and it should be kept How about a two checkbox option, one checkbox gives the traditional preview/no preview and a second opacity checkbox that overrides and greys out the preview checkbox ? IIRC, for the two checkboxes to indicate interaction, they should be within the same bounding box (might be wrong on that 'though). [image: 1663442639287-screenshot-2022-09-17-at-20.23.49-resized.png] Neil
  • Curate a list of currently un-used keyboard shortcuts
    @Boldline There is a new shortcut UI task in the backlog, but it is for after 1.2 When adding a shortcut, it should notify about the over write. And, in the shortcuts list, clicking on the "Shortcut" column title should sort in alphabetical order of of the keys, this might help.
  • Ungroup vs Unclip
    @William-Kansepa said in Ungroup vs Unclip: Am assuming that you mean Ungroup will no longer unclip Clipping Groups, but can still ungroup them from normal groups? I meant here "Ungroup All", not the basic "Ungroup" "Ungroup All", would only ungroup a group if it is not clipped..
    @Boldline I think it should paste above. I added this to the backlog.
  • SVG Export: support for real-world units
    @tudor I added this to the backlog.
  • Context toolbar - corner editor
    I don't understand why this would need to be in the context toolbar. Settings in the context tool bar should be things that someone might swap between frequently during their workflow. The option for single corner adjustment is a preference someone might make and then be done with it. It's not a setting that would need frequent attention or switching. Why would they need easy access to switch to the other method? All this does is clutter up the UI and take away real estate for other more applicable settings
  • Corner editor results and usability
    @VectorStyler said in Corner editor results and usability: @fde101 said in Corner editor results and usability: Why doesn't performing a "Reset Transform" before using the corner tool fix this? That would mean a convert to curves, just because the corner tool is activated. Can be done now manually. I was seeing this behavior with a random shape I created with the pen tool in order to try it out, so it should have already been curves? Not sure now, maybe I just wasn't looking at it right...
  • Corner radius
    @Ingolf Yes, this because only the corner selection are considered (not node selection). I added this to the backlog to have node selections act as corner selection for this.
  • Feature request: PowerPoint Export
    @Ingolf said in Feature request: PowerPoint Export: When the VS API becomes available, I guess it's something others could provide. It is probably faster and easier to have the API. But I add the PPTX format to the backlog anyway
