    • IngolfI
      Layer panel shouldn't disable common keyboard shortcuts
      @Ingolf This issue should be fixed in the latest build
    • encartE
      The parts of text becomes invisible after using Break Apart.
      @encart @b77 This problem should be fixed in the latest build
      Deleting text automatically moves text cursor to the far left side
      @Boldline This problem should be fixed in the latest build.
    • Qode5Q
      Can't scale individual objects after VS 1.1.002 Beta update.
      @Qode5 This problem should be fixed in the latest build, let me know if it still occurs.
      Pen tool sticking when attempting fine movements
      @Jono There have been some improvement in the Pen tool and how it handles snapping in build 1.1.008
      When Grouping fails occasionally....
      @Boldline Let me know if there are still issues of this kind when grouping .
      Symbol selection highlight not clearing after deleting object used to create symbol
      @Jono This problem should be fixed in build 1.1.008
      Path Brush tool seems to be acting like an eraser at times
      @Boldline This problem should be fixed in build 1.1.008 (part of the larger merge, union, divide fixes).
      Selecting all objects on a layer using the circle in the Layers panel does not allow for immediate keyboard arrow editing
      Offset Path affects neighboring shapes
      Repeater issue with expanded text
      Two words cut off in Crash Report Text
      Grouped blends that have not been expanded, are not able to be expanded together at the same time.
    • encartE
      [Repeater][Paste Inside] Shifted Expanding position, Shifted pasting position.
      @encart These problems should be fixed in build 1.1.008
    • encartE
      Breaking rotated text returns to the horizontal position.
      @encart This problem should be fixed in build 1.1.008
      Missing letter in repeater panel style option
    • encartE
      Manual resizing of the font disables setting the size of the font using the Alt key.
    • encartE
      [Appearance Panel]Multiple items are highlighted in panel's menu
      @encart Can be replicated! I will try to fix it.
      Two Layers Panels
      Thank you.
      Tools, Color panel
      Thank you.
