      Shape Builder tool creates unwanted oval at bottom of square shape creation
      @Boldline I'm happy to help
      Brush color turns to white despite it not being white initially or in color panel
      @Boldline Could be an issue with the brush not stretching correctly over shape. Send me the file containing the white brush.
      Bug in Layers panel
      OK. Sure I will. Thanks.
      It seems i have a "Save As" problem.
      @vectoradmin Great, thanks. Intalled and tested, seems every case work fine now.
    • IngolfI
      Layer / object must be highlighted to be hidden / visible
      Verified as fixed!
    • IngolfI
      Node handles moves node bug (beta 1.1)
      18k Views
      Verified fixed!
    • ambrosA
      Buggy behaviour when selecting line width for a circle (dashed line)
      ambrosA
      @vectoradmin brilliant. Glad you managed to isolate. Thanks
    • ambrosA
      Weird Issues with paper size
      ambrosA
      @vectoradmin that’s great news- very reactive- thank you
      Unintentional behavior of VS Application window
      @vectoradmin thanks for the fix, have had it figure out allready that it works now , in the beta
      Text in Non Displayable Font is Not able to be switched
      @Boldline This issue should be fixed in the new build 1.1.002 (beta)
      Preferences to set eraser indicator color do not seem to work
      Cutting and pasting blend has different name
      @Jono This issue should be fixed in the new build 1.1.002 (beta)
      Copied and pasted jpeg from the internet not displaying properly.
    • IngolfI
      Draw inside option missing
      @Ingolf This issue should be fixed in the new build 1.1.002 (beta)
    • IngolfI
      Option - double click doesn't work in shape editor mode
      Language menu is unusable
      @ash-f This issue should be fixed in the new build 1.1.002 (beta)
    • Qode5Q
      Files saved after VS Beta 1.1 update have no content.
      @Qode5 Could not replicate this issue. Let me know if it still occurs (beta 1.1.002)
    • IngolfI
      Beta 1.1 - double clicking in text mode should not activate node editing mode
      Offset Profile Width Display Not Keeping up with Selection
      Text not scaling for me
      @Boldline This may be related to the spacebar issue, and it is fixed in 1.1.002
