• TEXT OVERFLOW
    @rediguana I can confirm that this can be replicated here also. A fix will be available ASAP. EDIT: meanwhile, as a workaround, the path on which the text is set should be extended.
  • Artifacts on Gradient Mesh Gradients when zooming
    @Subpath Got it!
  • Lost background canvas of program
    18k Views
    Yes i found it. Yesterday the Navigator panel was covering the critical part. I've resized it and now have my program background. Thank you so much!
  • [Solved] Problems selecting objects after divide operation
    Of couse. D'oh. That was the last sign, going to bed. And thanks.
  • Bevel is completely broken (Image effects - Stylize)
    24
    41k Views
    Better in .058! [image: 1661734839064-16ed7101-29fe-419c-b012-695d1d60f300-image-resized.png] https://www.vectorstyler.com/forum/assets/uploads/files/1661726850039-b2008ef1-9aa2-4418-8798-c62d4bee7698-image-resized.png
  • Unsmooth mesh gradient
    @VectorStyler Fixed in .058! [image: 1661726238532-de7edde6-36f9-4fd8-862a-4ba8dd33ba35-image-resized.png]
  • Exported EPS file from VS not opening in older Corel programs
    17k Views
    @Boldline said in Exported EPS file from VS not opening in older Corel programs: or maybe run a virtual machine. I might try the latter - we'll see. I'm not sure Adobe still activates their CS suites…
    @Boldline Got the file, but cannot replicate it. See email
  • Creating a new layer makes everything else disappear
    @VectorStyler said in Creating a new layer makes everything else disappear: @tudor This regression should be fixed now. It is
  • The Panel of "Adjust with Mask " seems to be buggy
    @VectorStyler yes they can be changed I am used to panels keeping their settings. But I was surprised that this is the case even after a reboot. Since I can save prefs, I would like it better if the settings would be reset at least after a restart.
  • VS in "un-usable" state e.g. Undo no function
    @tudor This issue should be fixed now, please let me know if it occurs again.
  • Can't print direct from VS
    DazmondoD
    @Boldline Sorry this is a late reply -- I can now print to my Xerox Phaser 6180DN, providing its just A4 with no bleed - CMYK is pure, but can't get trim guides to work as expected or separations to print --- How do you get halftones to work?
  • Mesh editor stays active
    @VectorStyler said in Mesh editor stays active: @Ingolf This problem should be fixed in 1.1.049 Fixed in 1.1.050!
  • Adding a gradient with to a shape with a stroke
    @VectorStyler said in Adding a gradient with to a shape with a stroke: @Ingolf This problem should be fixed in 1.1.048 It is.
  • Custom toolboxes added to main toolbox
    @VectorStyler said in Custom toolboxes added to main toolbox: @Ingolf Toolboxes should not be able to dock into each other in build 1.1.049 Fixed, yes.
  • Current Tools in statusbar
    @VectorStyler said in Current Tools in statusbar: @Ingolf This problem should be fixed in 1.1.049 Fixed!
  • VectorStyler omits objects in a simple pdf-artwork
    @Raaskot This problem should be fixed in 1.1.048
  • Rotation pivot placing in the center after rotation
  • Right Click after selecting objects
