    • encartE
      Right Click removes the selection. Multiple items highlighted in the context menu.
      @encart This problem should be fixed in 1.1.048
    • encartE
      Expanded stroke changes its position
    • Devil DinosaurD
      Stroke appearance
      @Devil-Dinosaur This problem should be fixed in 1.1.048
      Pen Tool bugs
      moving shape after applying mesh gradient
    • encartE
      Entering an expression without a unit in the field results in an invalid position
      Keyboard numerical opacity shortcut not working on Mac M1
      @Boldline This problem should be fixed in 1.1.048
    • IngolfI
      Color panel slider issues - part 3 (color mode)
      @Ingolf This problem should be fixed in 1.1.048
    • Victor VectorV
      Character Style Presets do not switch in the Character Panel
      @Victor-Vector This problem should be fixed in 1.1.048
    • 861475_VctSt8
      Rome-Kana-Kanji conversion cannot be done with the SPACE key.
      @861475_VctSt This problem should be fixed in 1.1.048
      Unwanted artifacts in the history panel
      two undo steps to return nodes to original location when using alignment panel
    • IngolfI
      Restore minimized Window in two-monitor setup fails
      @Ingolf This problem was replicated and should be fixed in 1.1.048
      Grouping items in an open file then copying and pasting that group into new file breaks grouping
      "False start" with pen tool linked to "create shape entry in history panel
      @Boldline There were some problems around setting up undo. Right now, the Pen tool may leave a Create Shape item there, but only if a node is created. Let me know if this occurs again.
    • encartE
      Selecting all nodes from closed path (Ctrl+A) does not allow to move them.
      Pos1 and End Key misbehavior (Win)
      @Subpath This problem should be fixed in 1.1.048
    • Victor VectorV
      Bullet Labelling in Paragraph Options (issues)
    • Victor VectorV
      Text Frame Stroke Appearance Issue
    • Victor VectorV
      HLS Slider needs a black/white button fix
