    282 Topics
    228 Topics
    XRAYX
    @VectorStyler Sorry missed this. It's the result of the Undo/History bug. Sometimes this happens... I will keep recording and eventually I capture it. It's happened a few times. I'm not sure, but my guess would be the Object was originally meant to be a Layer... (I put everything in sublayers, generally) Edit: I wonder if my habit of Shift + {Click} New Layer/Sublayer might also add something not so nice to the History steps/recipe that might cause Objects that were moved around to get lost, as well? It's just a thought.
  • Adding swatches to default main color panel has issues
    @Boldline I will try to fix this for the next build.
  • Ghost Line request
  • Text Shortcuts not working
    @debraspicher said in Text Shortcuts not working: Are we 100% sure on that? Just because I was testing the Ctrl + V shortcut to see if it even worked at all and that's how I ended up with the Text Frame item Control+V is pasting on Windows. I meant the text frame conversion shortcut only exists on MacOS. What happened with the text frame: when a shape is selected and a text is pasted, then a text frame is created inside the shape, and the text flows into the shape. The problem was that this also happens when the selected shape is a text, and we get a text frame flowing inside the shape of a text. This is allowed in VS, but it should not do it when pasting.
  • The program crashes suddenly
  • Strange Behavior with UI in Settings Panel
    @debraspicher said in Strange Behavior with UI in Settings Panel: This blue line is visible in Settings and the Label is being clipped I will try to fix this.
  • Some bugs/quirks
    @Fertuffo said in Some bugs/quirks: Gradient fill expands limits to almost double the size when exporting in SVG. I could not replicate this (gradient fill svg export). Please send me a vstyler file that when exported to SVG results in expanded gradients, it might help replicating the issue. There could be a number of other attributes (transforms) that might cause this. Thanks!
  • Set style before drawing
    @Fertuffo said in Set style before drawing: @Fertuffo I mean, draw a line and try adding a new "Blue style". Then apply the "Blue style" to the same line and it turns non-value. This can be replicated, and it is a bug. Will be fixed ASAP.
    @VectorStyler said in Panel numerical slider does not show if panel is too close to screen edge: @Boldline yes, I think the new "slider alignment" feature made this worse. I will fix it ASAP. Sorry about that
  • Color palette panels grid margins
    @Ayo Seems that popup palettes do not use the option. I will fix this, and also place it into settings
  • Weird transform behaviour when altering fill color
    @Raaskot It is a refresh bug. Use Control+R (Windows) or Command+R (Mac) tor redraw. I will try to fix this ASAP.
    @Boldline said in Brush tool switches to different saved brush when width is scaled from Brushes panel: Would it help to send the workspace files? Yes, please send me those files. It could be some settings issue.
  • Bug
  • Tiny dropzone at the bottom of Layers panel
    @debraspicher I will try to improve this.
  • Appearance Panel>Opacity not responding to scroll wheel
    @debraspicher said in Appearance Panel>Opacity not responding to scroll wheel: May I suggest to move the slider so that when it is popped out, the knob/slider portion is just below the mouse cursor (provided there is space). I will try to add this.
  • Screen Glitches when Erasing Text Completely
    @debraspicher said in Screen Glitches when Erasing Text Completely: I opened a bug on this.
  • Node handles still disappear occasionally
  • Nodes behave odd in preview vector view
    @Raaskot Seems to be a bug.
