    282 Topics
    228 Topics
    XRAYX
  • The disappearing figure
    @monsterfox I will reopen this issue with the second file and try to find a solution for the next build.
  • Cannot use the cursor/arrow keys layers names
    @Raaskot I will test these options.
  • Actions file can no longer be opened
    26
    35k Views
    @pentool said in Actions file can no longer be opened: The error here is that the edits are not saved immediately to the file. I will find a fix for this for the next build.
  • A few issues with the colors/color styles/presets
    I think this aspect needs a rework as it is very confusing to know what goes where and how everything ideally things are saved and recalled. I always assumed features were implemented as needed and would get a rethink as time went on depending on overall usability and feedback.
  • Odd Menu Jitter...
    @VectorStyler I think that is when I started observing it, also. Sorry, it gets busy so I can't always make the needed report. Usually it is easier on the spot but kept in mind if I can't get to it yet.
  • Updated: Masked mesh gradients --> bad pdf
    @Raaskot said in Updated: Masked mesh gradients --> bad pdf: pdf still fails concerning mesh gradients in masks Yes, this is not fixed yet. The problem is that PDF does not support meshes as masks. I tested this with Illustrator also, and it will create some vector approximation of transparent meshes. I think the only solution will be to export these as images. I will try to add it to the PDF export, to export this as flattened image.
  • Bug
  • Graphic Tablet and Windows Ink
    @VectorStyler As you can see in the recording above, every time I start to draw a new line, there is a slowdown after about 2-3 sec. The biggest problem is with curves, spirals, etc.
  • Wrong choice
    @monsterfox said in Wrong choice: Selecting the blue line and following the operations in the video will also select the red line on the left at the same time. I will try to replicate this.
  • Weird panel behaviour
    @nocturnalYL Got it.
  • "Mojikumi" misspelled in Preset Manager
    @nocturnalYL Yes, thanks!
  • Gradient stroke vs fill editing
    @pentool I opened a bug on this. EDIT: yes this can be replicated and it is a bug.
  • Crash when editing gradient style color - UPDATE!
    @pentool Yes, seems that this kind of case was not fixed.
  • Crash when editing a gradient angle
    @pentool Replicated, will be fixed ASAP.
  • 16Bit Tiffs unsupported?
    @debraspicher This seems to be a bug.
  • Masked mesh gradients --> bad pdf
    @Raaskot It seems to be a bug, can be replicated here also. I will try to find a solution for this ASAP. EDIT: found the root cause, not yet sure when the fix can be available. The problem is caused by using transparent colors in the mesh gradient (these are not supported by PDF). I will try to fix this issue, but it might take some time.
  • Cosmetic issue - "Preset... Style..." menu order
    @pentool Will be fixed!
  • Color picker in gradient palette doesn't seem to work
    @pentool Yes, it can be replicated. I will try to find a solution for this. The problem is with the popup being closed before picking the color.
  • Cannot adjust gradient stop opacity through Stroke appearance
    @pentool Yes, this can be replicated. I will try to have it fixed before the next build.
