    282 Topics
    228 Topics
    XRAYX
  • rounded corner damage
  • “SAME FILE NAME”
    @VectorStyler Yes.
  • Inverted gradient when importing an '.ai' file
    @adrian Salut! Replicated and fixed! New build will be available in a day.
  • Copy and paste does not work after Windows 11 wake-up
    @VectorStyler After doing this the problem does not occur.
  • 'Bug
    @monsterfox Yes, it can be replicated easily, and it is a bug. The fix will be in the next build.
  • Snapping forces orthogonal
    @VectorStyler said in Snapping forces orthogonal: if the "Allow Snapping" (in Snapping panel) is disabled, then is there an issue? no issues when "Allow snapping" is disabled. I'm not having any problems at the moment with the snapping. I'll let you know. Thanks
  • stroke sizing popup remains permanently on the screen
    @Boldline I often encounter this problem too, but I just had a flash of inspiration. Maybe refreshing can solve it. You can try it next time.
    @VectorStyler Thank you for fixing that in latest build. Until now, I have had to use the import window. That was real pain in the neck.
  • Circles with corners?
    @Ingolf The corner option is shown for the case where the ellipse is a pie (starting and ending angle can be set in the Shape panel).
  • Strange behavior observed when drawing concentric ellipses
    @Ingolf Yes, this is a bug.
  • Noise fill doesn't apply
    I've just downloaded 1.2.072 and I see that the bug is fixed. Thank you !
  • Repeater Transform Issue
    @VectorStyler Thanks. It's a minor issue. this can be skipped.
    @Boldline said in Changing stroke color with the option modifier enabled does not let me do so from objects on the artboard: Am I missing something to allow that? No, this is not supported. If not, could that be added? I will try to add this, have to check if there is an available modifier for this while picking color.
  • Issues with the default printer, and Adobe PDF
    @Arde This could be caused by loading the last used printer options at startup. Try printing with an other printer and change the last used printer.
  • Could active blends be expanded with the expand clip groups?
    @VectorStyler Just to clarify, my issue was that I could not figure out what step I had forgotten to do at the end of the project. I had left the blend active in case I needed to make a change later. When I got the error while expanding the clipped live blend, it took me a while to realize my issue. So whether there is a warning that pops up that reminds the user they have live blends to attend to before it can act or it just expands it automatically for them - whatever is best for VS is what I prefer.
  • Trim and join tool bug
    @VectorStyler Ok, thanks
  • Not a group.
    @monsterfox It is not a bug, more like a naming issue. In VS there is a shape type that contains multiple paths. This is called the "Path Group" shape.
  • noise gradient doesn't rescale
    @EricP Yes, it can be replicated here. The Scale (maybe should be named Stretch) value is not supported by the Noise mode. I opened a bug on this to find a solution.
    @VectorStyler let me know if you need me to send over anything or make another video to help narrow it down
  • curve
