    282 Topics
    228 Topics
    XRAYX
  • Old files & activated fonts with...
    @B-Vs-V said in Old files & activated fonts with...: an old design made with an earlier version is no longer correct (blending feature). yes, this might have happened with 1.2 (about a year ago), if the file is older. Send me an example and I will try to figure it out. I opened a bug with the Fondbase case. Are these TTF or Type1 fonts?
  • Graphic replacement error
    @VectorStyler [image: 1744971871472-dd3941ef-0146-4b7f-9d06-d939df2ce8e1-image.png]
  • Graphics without color information
    @monsterfox Yes, I think this was by design. If there are no attributes (fill or color) then it might be skipped when exporting. I have to check if it is possible to export these.
  • Unit of measurement
    @monsterfox If you previously typed a unit in some number editor, then that will be kept for that number editor. Also, some number fields default to specific units.
  • Issue with Contour
    Since I don't want to change the W display scaling, I have to wait for the fix to proceed further...
  • The handle can control the anchor point
    @monsterfox said in The handle can control the anchor point: Why does this happen sometimes but not always?" Could be the issue with the box selection. I will check that.
  • Appearance panel - colour symbol
    @B-Vs-V These should be in c:\Users<user name>\AppData\Roaming\NumericPath\VectorStyler1.2\vector\data\resources\ (the "Roaming" folder can also be "Local")
  • Appearance panel
    @VectorStyler I already sent you the file.
  • Bug
  • Path lengthening tool
    @monsterfox @Subpath I will try to improve this.
  • Symbol Stamp Tool / Symbol Spray Brush Bug
    @Harry I opened a bug on this.
    @Boldline In the 3rd column select a replacement mode: in this case try "Exact".
  • Bug
    @monsterfox Now I get it. What happens here is that if a shape has closed parts (as in this case one circle remains closed), then the fill will be applied to the open part also.
  • Source
    @VectorStyler I've found a solution to the first cloning issue by selecting "Copy on Duplicate" in the Duplication Mode. However, the second issue (with the Shape Replacement Tool) remains unresolved. The two options you mentioned are still grayed out in my interface, and I'm unsure how to activate them.
  • Bug in ruler
    Sorry, I was fooled by the zoom level. If I zoom in closer, the ruler actually shows the value 2000. I was fooled by the full extension view, where it shows 1995 near the margin and not 2000
  • Bug
    @monsterfox I will try to fix this for the next build.
  • BUG
    @monsterfox Yes, this can be replicated and it is a bug. Will be fixed for the next build.
  • Two Styles panels
    @monsterfox I will try to replicate this. (for some panels multiple instances are allowed by design, but maybe not in this way).
  • Opposite constrained move?
    @fdarnel Yes, there are some issues here caused by the transforms on the group. I will try to find out more about this.
  • Problem selecting layer name
    @fdarnel Got the recording, I will try to replicate and fix this.
