    292 Topics
  • HSL sliders behaviour in CMYK document
    @VectorStyler lot's of options. That's great. Thanks for this great software and your perfect support
  • Rotating a Repeater object causes a crash
    @VectorStyler No more crashes when rotating. Thanks!
  • Rounding Tool
    1k Views
  • Two Bugs
    @VectorStyler https://youtu.be/uQ7xkmFEKWQ?feature=shared
  • Four errors
    @monsterfox said in Four errors: When using the rounded corner tool in Outline mode, ghosting was found I opened a bug on this.
  • Gradient copy paste to Affinity
    thanks for the bug fix in last release. Fantastic support !
  • Node Bump's “Randomized” issue
    @VectorStyler Thanks for the fast fixes.
  • rounded corner damage
  • “SAME FILE NAME”
    @VectorStyler Yes.
  • Inverted gradient when importing an '.ai' file
    @adrian Salut! Replicated and fixed! New build will be available in a day.
  • Copy and paste does not work after Windows 11 wake-up
    @VectorStyler After doing this the problem does not occur.
  • 'Bug
    @monsterfox Yes, it can be replicated easily, and it is a bug. The fix will be in the next build.
  • Snapping forces orthogonal
    @VectorStyler said in Snapping forces orthogonal: if the "Allow Snapping" (in Snapping panel) is disabled, then is there an issue? no issues when "Allow snapping" is disabled. I'm not having any problems at the moment with the snapping. I'll let you know. Thanks
  • stroke sizing popup remains permanently on the screen
    @Boldline I often encounter this problem too, but I just had a flash of inspiration. Maybe refreshing can solve it. You can try it next time.
    @VectorStyler Thank you for fixing that in latest build. Until now, I have had to use the import window. That was real pain in the neck.
  • Circles with corners?
    @Ingolf The corner option is shown for the case where the ellipse is a pie (starting and ending angle can be set in the Shape panel).
  • Strange behavior observed when drawing concentric ellipses
    @Ingolf Yes, this is a bug.
  • Noise fill doesn't apply
    I've just downloaded 1.2.072 and I see that the bug is fixed. Thank you !
  • Repeater Transform Issue
    @VectorStyler Thanks. It's a minor issue. this can be skipped.
    @Boldline said in Changing stroke color with the option modifier enabled does not let me do so from objects on the artboard: Am I missing something to allow that? No, this is not supported. If not, could that be added? I will try to add this, have to check if there is an available modifier for this while picking color.
