    292 Topics
  • Ungrouped Text frames doesn't keep their properties
    @VectorStyler Thank you. I was tearing my hair out trying to fix this.
  • Duplicating objects does not preserve their position
    1k Views
    @encart Can be replicated. This is a bug caused by a movement in Layer 1. I will try to fix this for the next build. As a workaround, create a new Latey (next to Layer 1) and move the content of Layer 1 into the new layer.
  • Regression with 1.2.075 : pencil shapes disappear
    @VectorStyler thank you. That makes sense
  • Brush Panel brush display changes display settings when not in use
  • 4Bugs
    @monsterfox said in 4Bugs: After undoing all operations, the newly drawn graphics don't overwrite previous records. Instead, both the new and original records remain, similar to a snapshot function. I wonder if this counts as an error This is not an error. Actually in VS the History is a hierarchy (not a list), meaning that you can go back to alternate histories.
  • rgb color profile dropdown duplicate items
    color profiles rgb color bug
    @brentpruitt This can be replicated here also (on Sonoma), but it is not really a bug. The system (ColorSync) contains a few ICC display profiles that all have the same name. It is not clear why Apple added these to Sonoma, it is not in other MacOS versions. The only thing I can do with this is to show the file name instead of the profile name stored in the file, but that can lead to other issues.
  • Bugs
    @monsterfox said in Bugs: Graphics within a clipping group show offset issues. This one is not a bug. The orange shape (for the Move Inside) is distorted with a Warp effect (small amount). When moving the green lines inside this object, the lines also become distorted, causing a small change on their shape.
    @brentpruitt I added this to the backlog.
  • Move Character and Paragraph Style panels to Text menu
    @VectorStyler I understand. Perhaps move them to Window/Text then. Makes more sense. [image: 1752134187028-87b601d1-e629-4b23-8721-29801080fe2c-image-resized.png]
  • Possible Error in Properties Panel Transform > Scale
    @Wolfgang Yes, this seems to be an error, the field has the wrong lower limit. The Transform panel should display the correct scale. This will be fixed in the next build
  • Bugs on node editing
    @VectorStyler Thanks very much
    @Boldline I tested this with a simple example, but could not replicate it. Send me a sample by email, where expanding a clipped group cannot be undone. Might be caused by some specific object attribute.
    @Raaskot Yes, I remember there were mesh exporting issues with PDF. I will try to replicate and fix these.
  • Forum bug?
    Okay, I've been keeping an eye on that. It only appears for the last thread in the list of unread posts. To my surprise, it also appears when I open the topics in the list in a new tab. So the last tab with the last topic in the list took a while to load. I don't know exactly. But I'd guess it was 15-20 seconds. All the others loaded instantly. I was using Firefox.
  • Pdf-file: no show on loading
    @VectorStyler Ignore previous. After restart of Mac I cannot replicate it either, and it seems to work fine all over. If it appears again I'll let you know.
  • Log
    @monsterfox Yes, it is the same here. I will try to improve this. There are over 400 objects, doing this in smaller sets might be faster.
  • UI error; Layer names in list dissapears on double click
    @Raaskot On mac they should be in: ~/Library/Application Support/VectorStyler1.2/vector/data/resources/ folder But for Mac App Store version, these folders are well hidden by MacOS and different for every user. You can also try the Help -> Reveal Workspace Folder command.
  • Font previews don't work
    @VectorStyler Yes. I keep font collection on my drive and added some folders via Font Manager.
    @Boldline I cana replicate this issue here also. Select the Object -> Shape -> Clear Shape Builder State, this will reset all previous shape builder states.
  • Bug
