    292 Topics
  • Spelling error
    @Boldline Thanks for noticing. will be fixed in the next build.
  • 'Repeater', bug ?
    @B-Vs-V Set the Expand amount to 0 (this expands the shape), and enable the "Restrict Using Shape" option.
  • There is a crash issue with Repeater
    @VectorStyler Fixed. thanks
  • Invalid issue with the corner shape button
  • two bugs
    @Li-Xiao said in two bugs: There is indeed an issue with selecting the line mode Yes, this was the key. I will try to fix this as soon as possible.
  • Symbol
    @VectorStyler I haven't tried to reproduce the issue. As for moving the layers ,I can't see the blue destination line: it's not sufficiently marked (sorry for my terse sentence)
  • Coordinate start ikon a bit confusing
    @Raaskot Yes, this is indeed the case. The icon does not depend on the coordinate direction. I will think of a solution.
  • Old files & activated fonts with...
    @B-Vs-V said in Old files & activated fonts with...: an old design made with an earlier version is no longer correct (blending feature). yes, this might have happened with 1.2 (about a year ago), if the file is older. Send me an example and I will try to figure it out. I opened a bug with the Fondbase case. Are these TTF or Type1 fonts?
  • Graphic replacement error
    @VectorStyler [image: 1744971871472-dd3941ef-0146-4b7f-9d06-d939df2ce8e1-image.png]
  • Graphics without color information
    @monsterfox Yes, I think this was by design. If there are no attributes (fill or color) then it might be skipped when exporting. I have to check if it is possible to export these.
  • Unit of measurement
    @monsterfox If you previously typed a unit in some number editor, then that will be kept for that number editor. Also, some number fields default to specific units.
  • Issue with Contour
    Since I don't want to change the W display scaling, I have to wait for the fix to proceed further...
  • The handle can control the anchor point
    @monsterfox said in The handle can control the anchor point: Why does this happen sometimes but not always?" Could be the issue with the box selection. I will check that.
  • Appearance panel - colour symbol
    @B-Vs-V These should be in c:\Users<user name>\AppData\Roaming\NumericPath\VectorStyler1.2\vector\data\resources\ (the "Roaming" folder can also be "Local")
  • Appearance panel
    @VectorStyler I already sent you the file.
  • Bug
  • Path lengthening tool
    @monsterfox @Subpath I will try to improve this.
  • Symbol Stamp Tool / Symbol Spray Brush Bug
    @Harry I opened a bug on this.
    @Boldline In the 3rd column select a replacement mode: in this case try "Exact".
  • Bug
    @monsterfox Now I get it. What happens here is that if a shape has closed parts (as in this case one circle remains closed), then the fill will be applied to the open part also.
