    292 Topics
  • Issues with the default printer, and Adobe PDF
    @Arde This could be caused by loading the last used printer options at startup. Try printing with an other printer and change the last used printer.
  • Could active blends be expanded with the expand clip groups?
    @VectorStyler Just to clarify, my issue was that I could not figure out what step I had forgotten to do at the end of the project. I had left the blend active in case I needed to make a change later. When I got the error while expanding the clipped live blend, it took me a while to realize my issue. So whether there is a warning that pops up that reminds the user they have live blends to attend to before it can act or it just expands it automatically for them - whatever is best for VS is what I prefer.
  • Trim and join tool bug
    @VectorStyler Ok, thanks
  • Not a group.
    @monsterfox It is not a bug, more like a naming issue. In VS there is a shape type that contains multiple paths. This is called the "Path Group" shape.
  • noise gradient doesn't rescale
    @EricP Yes, it can be replicated here. The Scale (maybe should be named Stretch) value is not supported by the Noise mode. I opened a bug on this to find a solution.
    @VectorStyler let me know if you need me to send over anything or make another video to help narrow it down
  • curve
  • Trim and Join Tool generates duplicates
    @Fertuffo I opened a bug on this.
  • Some questions
    @monsterfox I opened a bug on these.
  • outline mode
  • A clipping group with color information
    @monsterfox The problem is that other drawing apps do not support filled (or outlined) clipping groups. If these are not separate, then the stroke on the clipping group is also clipped (and it should not).
  • Can't expand text on path
    @Fertuffo Fixed!
  • Stroke Width "Adjust Profil with Masks" seems to be buggy
  • The cloned object causes incorrect positioning when placed on the path.
    @VectorStyler Thank you.
  • menu items : none
    @B-Vs-V Fixed
  • Bug
    @VectorStyler I don't remember the exact name, but it's an option in the selection menu that's the opposite of "Select Parent." It's definitely not called "Child."
  • Strange error
    @monsterfox said in Strange error: I can replicate all these issues. Some are bugs, other are just the result of the reference trick in VS (but I will try to improve these also). Uniformly increasing or decreasing the size of graphics with the same dimensions can result in two different outcomes. This one is not a bug. The problem here is that the last two objects are references of other previously selected objects. Now if both the reference and its source is selected and we scale these, then the source is scaled (order does not matter), which makes the reference smaller, and then the reference is scaled again. So basically the reference was scaled twice (once its content and once the link). It is easy to replicate: draw a shape, Edit -> Reference, select both and scale. Not sure what would be a solution here (no one has the reference feature), but I will think of something. When converting the graphic to a path, the size shrinks, and it only returns to normal after converting it a second time. Again a result of the reference feature. When converting a "reference" (symbol) to curves, it will not convert it, but it will remove any transforms/shape effects on it, resulting in the smaller objects. Symbols (or references) should be expanded first with Style -> Expand Symbol. The solution here would be to automatically do an Expand Symbol when doing a convert to curves. When increasing the size of a graphic without selecting the stroke, the stroke may appear thicker. Here the problem is with the "too many options" of VS. Because we can have multiple strokes per object, each stroke can set if it is scaled or not when resizing (even if the object itself turned off the Transformed Stroke option). This Stroke level object can be accessed in the Appearance panel, by selecting the Stroke item and the Transformed Content in the panel menu. When simultaneously selecting a path and the underlying image to perform a node-disconnecting operation, issues may arise with the underlying image. This one is a bug, will be fixed. Graphics that are no longer in a grouped state can still undergo an unlimited number of ungrouping operations. This is also a bug, will be fixed.
  • Replace font properties
    @monsterfox The Object Shape checkbox means that the shape is copied. If the VS point text (text shape) the text itself is the "shape" of the object. This allows things like using editable text for clipping.
  • The issue of moving after removing transform
    @Li-Xiao Not really a bug, but it can be confusing. The problem is that the transform is on a group (with a single object content), and inside that group the object is moved. This transform then applies to the movement also, and removing the transform will make the movement much smaller. It is quite easy to create this scenario: create a group of 2 or more objects. transform the group (make it 2x larger). isolate the group and move one object away from the rest. select the group and remove the transform. the object that was moved further away will have some movement back. removing the other objects from the group, before removing the transform will make this "offset" more confusing.
  • Bug
    @monsterfox Yes, this was mentioned before with references and clones, but scaling and rotation of these are always centered. I have a task open for this (in the features backlog), and I will try to find a solution
