    290 Topics
    There is a workaround that requires using Shape Corner in the Effects panel. However, this only works if all four corners of the rectangle have the same radius. If the corner sizes are inconsistent, Shape Corner doesn't allow for individual corner adjustment, and you have to use the Corner panel instead, which makes this workaround unusable for that scenario. https://youtu.be/akNbqo8wqo8
  • Multi-object operation
    @monsterfox Case (2) is problematic: here both effects are applied to both objects, causing the addition of the Transform to one of the objects.
  • More space needed for input numbers in Grid panel
    1k Views
    @Boldline Will be fixed in the next build
  • The alignment panel UI display issue
    Fixed. thanks
  • Node tool group select selects other connected shapes
    @VectorStyler Thank you! that would be a great ease of use fix.
  • Ability to move multiple selected objects at same time stops functioning
    I closed the file itself and reopened it. I did not close out Vectorstyler entirely
  • Snap-to-Point Fails When Occluded by Non-Snappable Objects (e.g., Text)
    I have a problem reproducing it from a clean file. I have a somewhat complicated file where it shows up. May be a memory issue. I'll try to reproduce on something cleaner and resubmit if I can. Thanks.
  • Regarding the disappearance of ghost lines
    @hbalcic This is not a bug: if the object has a valid fill, then the selection highlight is not shown while moving. The selection frame can be enabled for moving in the transform tool options (opened from context panel first button).
  • CMYK Sliders crashing
    @oleGraf Got the crash reports of VS when running on MacOS High-Sierra. I think there are issues here with Metal (not well supported for Intel GPUs of that version) If you can start with a fresh VS install (and no user data, workspace or settings) and disable Metal use in Settings -> Performance (for this machine use OpenCL or Software mode) this might help.
  • Shift+ letter combination activates tools when editing text.
    1k Views
    @encart I opened a bug on this
  • Ungrouped Text frames doesn't keep their properties
    @VectorStyler Thank you. I was tearing my hair out trying to fix this.
  • Duplicating objects does not preserve their position
    1k Views
    @encart Can be replicated. This is a bug caused by a movement in Layer 1. I will try to fix this for the next build. As a workaround, create a new Latey (next to Layer 1) and move the content of Layer 1 into the new layer.
  • Regression with 1.2.075 : pencil shapes disappear
    @VectorStyler thank you. That makes sense
  • Brush Panel brush display changes display settings when not in use
  • 4Bugs
    @monsterfox said in 4Bugs: After undoing all operations, the newly drawn graphics don't overwrite previous records. Instead, both the new and original records remain, similar to a snapshot function. I wonder if this counts as an error This is not an error. Actually in VS the History is a hierarchy (not a list), meaning that you can go back to alternate histories.
  • rgb color profile dropdown duplicate items
    color profiles rgb color bug
    @brentpruitt This can be replicated here also (on Sonoma), but it is not really a bug. The system (ColorSync) contains a few ICC display profiles that all have the same name. It is not clear why Apple added these to Sonoma, it is not in other MacOS versions. The only thing I can do with this is to show the file name instead of the profile name stored in the file, but that can lead to other issues.
  • Bugs
    @monsterfox said in Bugs: Graphics within a clipping group show offset issues. This one is not a bug. The orange shape (for the Move Inside) is distorted with a Warp effect (small amount). When moving the green lines inside this object, the lines also become distorted, causing a small change on their shape.
    @brentpruitt I added this to the backlog.
  • Move Character and Paragraph Style panels to Text menu
    @VectorStyler I understand. Perhaps move them to Window/Text then. Makes more sense. [image: 1752134187028-87b601d1-e629-4b23-8721-29801080fe2c-image-resized.png]
  • Possible Error in Properties Panel Transform > Scale
    @Wolfgang Yes, this seems to be an error, the field has the wrong lower limit. The Transform panel should display the correct scale. This will be fixed in the next build
  • Bugs on node editing
    @VectorStyler Thanks very much
