@Ayo said in Convert Text to ...:
Convert to what?
It converts between shape and frame text. I will add a better (automatic) naming based on the selection.
Thank you. Then it works.
Divider could maybe use some contrast?
[image: 1698768493506-2af82131-857b-4c77-a405-51cbb8e5c96d-image-resized.png]
@Ayo said in Delete one swatch color group, group disappears:
In grid mode is it nearly impossible to recognise you are dealing with a group!
A mistake in the Light UI theme
@Subpath said in Pen Tools Dot:
The gap in the new one could be a little narrower for my taste
It's just a suggestion to illustrate my point. No optimized design. However, I immediately noticed when creating the symbol that a center line must be thicker than the white overall outline. For overall weight balance and preventing filling up in tiny size.
@b77 Using a mouse.
Followed your procedure and problem is solved Indeed!
Still annoying that that happens.
Will send the .xml files to the developer's email.
@Ayo said in Some comments and advice about the Layers panel:
I also wonder why there is the need for two magnifying glasses. One seems sufficient to me. Symbol on the right with the tiny cross is probably intended as a 'Clear' symbol. In that case, a simple cross will symbolize its function more clearly.
@Ingolf said in Some comments and advice about the Layers panel:
The current bottom placement is therefore my favorite when it is displayed permantly. I actually forgot it was there because it never distracted me.
So all in all I prefer it in the bottom if it will always be visible.
Same for me.
@Boldline said in [Using Record It does not allow me to see panels or press buttons in VS]
Hmm I just updated both machines to the new Sonoma OS.
Edit your signature!
@VectorStyler I thought so. Somewhere else you call it 'containers'. It is more a stack order panel.
Layers, groups or containers, it is simply not correct to include varieties of pears under the heading of apples.
This is actually an older discussion and/or feature request.
https://www.vectorstyler.com/forum/topic/3294/ideas-to-improve-the-vectorstyler-layers-panel/48
@Ayo After changing the canvas color in Document Setup > Guides you can
save the document as a preset:
[image: 1698056168266-gsef.png]
Any new document will have this setting by default until you change it or add a
different preset.
(The preset will be available in File > New Document Setup > Document Presets).
