    3. VectorStyler 1.2 beta
      Blend panel
      @Pat Will fix this ASAP.
    • 861475_VctSt8
      JIS paper size
      Paragraph styles
      @VectorStyler file sent. Thanks
      Artboard layout - issue with snapping to guides
      @Pat Got the file, and opened a bug on this one.
      Horizontal orange temporary guide line when moving objects, the horizontal line seems thinner than the others
      @Boldline I cannot replicate this here on retina.
      Is resetting the workspace to default supposed to also set the settings to default?
      @Boldline I will test this, normally it should not reset the settings.
      Could custom shape applied to erase tool also work when cursor is moving?
      @Boldline No, only for click erase and when holding Option(Alt) key to start erasing.
      Add an option to shrink the panels to JUST the icons themselves? sans words?
      @Boldline It seems that the issue occurs only when the panels are docked.
      Add option to font manager to add existing live fonts in document to document level save
      @Boldline said in Add option to font manager to add existing live fonts in document to document level save: what does VS do currently when it opens a saved file that has live fonts within? Yes, it scans the fonts from the document. This is OK to do once at startup. But as the document changes it will need to do again. It is not enough to just remember the font changes. The problem is that it will not know if a font change overwrites some other font or it is a new font.
      Shrinking panels to icons does not always place the panels flush to the right side
      @Boldline yes, there are some issues when the panels are docked.
      Allow settings panel to be sized by user - also add scroll bar for topics
      @b77 oh ok i see what you mean with the transparency now. I like that and agree that should be added for greater clarity of what section title is selected
      Suggestion: delete "recent documents"
      @Pat yes, added this to the backlog.
