• VectorStyler 1.2 beta
    Pinned Moved
    12 Votes
    17k Views
    @Victor-Vector said in VectorStyler 1.2 beta: Just so you know, this works 100% with my keyboard's left ALT but it is jittery on my keyboard's right ALT. Yes, there were some issues in working with the right ALT key on Windows. I will try to improve this.
  • Regression when working with placed high resolution images
    @VectorStyler said in Regression when working with placed high resolution images: Offline VectorStyler 19 days ago @William-Kansepa Can you send me the image by email? Thanks! Sorry for the delayed response. Unfortunately, this behaviour still persists even in VS 1.3.032. I have send an example file to your email.
  • Regression when increasing or decreasing stroke width
    @VectorStyler Thank you for your response. Please note that the lag takes place when you long press the bracket keys.
  • Rounded corners regression after applying effect
    There is a workaround that requires using Shape Corner in the Effects panel. However, this only works if all four corners of the rectangle have the same radius. If the corner sizes are inconsistent, Shape Corner doesn't allow for individual corner adjustment, and you have to use the Corner panel instead, which makes this workaround unusable for that scenario. https://youtu.be/akNbqo8wqo8
  • PDF fails to open and displays a blank artboard
  • The latest VS update is failing to display some jpeg images.
    This issue is now resolved! Thank you @VectorStyler!
  • Stretched side panels
    I haven't restarted VS as yet and the panels keep on expanding... These are the results: [image: 1778071646134-stretched-panels-02.jpg]
  • Typo error
    @William-Kansepa Will be fixed
  • Change Screen Mode does not work
    @VectorStyler said in Change Screen Mode does not work: Is this the "Single Document View" mode? this should be inactive if no document is open. This is happening when I have open documents.
  • Replacing linked image caused file size to balloon
    @William-Kansepa said in Replacing linked image caused file size to balloon: If you check in Links panel, the image is still linked not embedded. Yes, but a copy of the image is also in the file. I will check why this happens.
  • Transform pivot point regression
  • Regression when placing images
    This is now fixed in the latest update!
  • 1.2.075 Properties Panel resize problem
    @larsherold I opened a bug on this.
  • Round Corners Bug
    @William-Kansepa said in Round Corners Bug: Scale Corners option I added this to the features backlog, but I'm not sure yet how this can be done.
  • 测试中文版
    @朱升品 I added your email to the license server. Please restart VS.
  • Crash report after reopening VS
    @debraspicher said in Crash report after reopening VS: However, deleting the folder did the trick for me, thankfully. Yes, this might happen if VS cannot delete the previous crash log files. Manual deletion fixes this.
  • stacked Transform shape effects should be independent
    @VectorStyler Ah - I had been interpreting the order wrong - I thought it's built "base up". Yes, now it works and makes very much sense. @Devil-Dinosaur I downloaded your preset and now need to find out how to load it I was thinking about shape effects because this can then be wrapped into a Layer style, so there is some kind of workflow of "switch off layer effect visibility to draw -> turn on effect visibility to see" and keep everything live.
  • Crash when objects with Erase blend mode duplicated
    @jkwchui Can be replicate here also, will be fixed as soon as possible.
