• Typography 2: 'Auto' is a relative value
  • Typography 1: Paragraph Leading
    @Ayo said in Typography 1: Paragraph Leading: Still want me to stay connected? Absolutely. I know VS is a bit of an acquired taste I'm a bit slow today, preparing the new build (will take some time).
  • Typography
    @Ayo said in Typography: Should I report other issues ? Yes
  • Convert Text to ...
    @Ayo said in Convert Text to ...: Convert to what? It converts between shape and frame text. I will add a better (automatic) naming based on the selection.
  • Text-trouble
    @Ayo said in Text-trouble: Should be resolved anyway. Yes, it is a bug.
  • Crash Report misses 'Send'
    @Ayo said in Crash Report misses 'Send': Are they automatically deleted after a real save? yes they should be
  • Layers panel 'preview drag and drop' switch working?
    @VectorStyler Thank you. Then it works. Divider could maybe use some contrast? [image: 1698768493506-2af82131-857b-4c77-a405-51cbb8e5c96d-image-resized.png]
  • Delete one swatch color group, group disappears
    @Ayo said in Delete one swatch color group, group disappears: In grid mode is it nearly impossible to recognise you are dealing with a group! A mistake in the Light UI theme
  • Impossible to trace with Pen tool
    @Li-Xiao I managed to replicate this issue. The fix will be in the next build.
  • Snap to Points doesn't seem to work
    22
    36k Views
    @Subpath said in Snap to Points doesn't seem to work: works pretty well Indeed! And another point for the Node Tool! (my favourite default) Thanks!
  • Trouble with Eraser tools
    @Ayo Looks like the path eraser tool has a bug when erasing the whole shape. Added these issues to the backlog.
  • Pen Tools Dot
    @Subpath said in Pen Tools Dot: The gap in the new one could be a little narrower for my taste It's just a suggestion to illustrate my point. No optimized design. However, I immediately noticed when creating the symbol that a center line must be thicker than the white overall outline. For overall weight balance and preventing filling up in tiny size.
  • Can't move combined selection
    24
    42k Views
    @b77 Using a mouse. Followed your procedure and problem is solved Indeed! Still annoying that that happens. Will send the .xml files to the developer's email.
  • Some comments and advice about the Layers panel
    @Ayo said in Some comments and advice about the Layers panel: I also wonder why there is the need for two magnifying glasses. One seems sufficient to me. Symbol on the right with the tiny cross is probably intended as a 'Clear' symbol. In that case, a simple cross will symbolize its function more clearly. @Ingolf said in Some comments and advice about the Layers panel: The current bottom placement is therefore my favorite when it is displayed permantly. I actually forgot it was there because it never distracted me. So all in all I prefer it in the bottom if it will always be visible. Same for me.
  • Using Record It does not allow me to see panels or press buttons in VS
    @Boldline said in [Using Record It does not allow me to see panels or press buttons in VS] Hmm I just updated both machines to the new Sonoma OS. Edit your signature!
  • Quite pleasantly surprised with the Extend path tool
    @encart BTW: a path can also be extended automatically to the next intersection with the Trim and Join tool.
  • Artboard Label seems not to work
    @Ayo Thanks for reporting this. I added it to the backlog as a bug.
  • Homeless objects
    @VectorStyler I thought so. Somewhere else you call it 'containers'. It is more a stack order panel. Layers, groups or containers, it is simply not correct to include varieties of pears under the heading of apples.
  • Send objects to current layer
    @VectorStyler This is actually an older discussion and/or feature request. https://www.vectorstyler.com/forum/topic/3294/ideas-to-improve-the-vectorstyler-layers-panel/48
  • Indicators showing while invisible
    @VectorStyler said in Indicators showing while invisible: find a solution Perhaps 'Invisible = locked too (in the background)'? Locked can be visible.
