• New release - doesn't install
    Yes indeed, I had also allowed the "repair" of VectorStyler the first time not knowing what to do, and the complete installation succeeded after the fix of the beta version.
  • Should the live text blue line extend beyond the word?
    @Boldline @b77 I opened a bug on this one.
  • Number Editing issue
    @Ayo said in Number Editing issue: Checked it again and it works! Don't get it. Could be that after opening the slider popover, it does not react to the first click.
  • Pencil tool keeps selection longer than necessary
    @Boldline Yes, this is a "highlight" indicator for shape drawing. It shows that those objects are still selected.
  • Scaling objects
    @Kumr thanks for reporting this. it can be replicated here also. it is caused by the large corner size at small rectangle size. I opened a bug on this one.
  • Transform (rotate) in Text Editor reference point
    @Ayo said in Transform (rotate) in Text Editor reference point: copy/paste from webpage into frame There might be something here. I have to replicate this.
  • Node tool on shape adjustment crashes VS
    @VectorStyler Grouping "solved" the issue
  • Lorem Disabled
    @Ayo As a workaround for now: it requires a second click.
  • Improvement is poorly noticed if the problem no longer exists
    @VectorStyler Yes
  • Impossible to give a stroke value to blended objects
    @VectorStyler The bug is fixed... Thanks for this rapid update & fix
  • Settings: retain certain values
    31
    46k Views
    @Pat said in Settings: retain certain values: Still there when I reduce some panels. I could not replicate this yet. Send me the workspace and settings files from the /resources/ folder
  • Autofill option under guidelines panel
    @VectorStyler I restarted my system and that setting disappeared. No clue what happened. Will check on Mac Utility part. Thanks
  • Unable to use 'Shift' to extend selection
    @Ayo said in Unable to use 'Shift' to extend selection: Works, but I have to start from scratch again. Changing my settings It could be that some of these settings changes caused the Shift+ issue. So next time the Shift+ problem occurs, just zip all those files in the resources folder (they contains the user settings and the workspace customizations) and send them to me.
  • Nodes, Name of artboard and corners of warp tools seem oversized
    @Boldline Looks normal here (also 27"). I will test on a macbook pro. Are there some settings that were changed related to Node or Screen scaling?
  • Release to Layers (seq.), designed this way?
    @Ayo I opened a task on this one. Lets see what is the feedback.
  • Shape/Frame Text not accept 'Paste' text
    @Ayo It is a bug, will be fixed ASAP.
  • The shapes flew out
    @VectorStyler This bug has been fixed also. Thank you.
  • Looks like a bug in the Bending
    @VectorStyler This bug has been fixed. Thank you.
  • Typography 2: 'Auto' is a relative value
