    @syllie Yes, it is in the backlog and not yet implemented.
  • Auto-snapping a shape to 90 degrees keeps shape from being rotated freely
    @VectorStyler ok no problem. Thanks for the explanation. I'm glad this is fixed and improved upon already for a future update. Sounds like it will be a real game-changer when it's officially released. I can make do for now until then.
    @vectorstyler @b77 thank you both for explaining. That makes sense now.
  • Unintentional Opacity in a Noise Gradient
    @Subpath it should work with Software at least in all cases, so this might be a bug unrelated to the GPU.
  • Can PDFs be exported from VS with layers honored?
    @VectorStyler ok no problem. It's not an urgent thing. In the long term it would be a great addition to add layers to PDF because it would give VS an alternative export with layers option besides strictly native VS files.
  • Colorize: Randomize dose not included the last color in palette
    In this case, it should be a random deselected but it could be anything, a new selection mode or a new tool or command but it is not high priority. Thanks
  • "Reselect" tool purpose?
    @Boldline Agree, no need to make it an entirely new option. It would in essence be a Reselection of the last Deselected / Dropped regular selection set. Regardless of how the Selection set was established. So Reselect would be active from a "No Selection" status. It would act like "Undoing" a Deselection, as @b77 described.. /Lars
  • Align does not always seem to do the right thing
    @Boldline Can be replicated here also, it is a bug.
  • Status bar show wrong information.
    @mtinra This seems to be a bug, and can be replicated here also. Added it to the backlog.
  • Weird behavior when repeating duplicate with a rotated object.
    @syllie said in Weird behavior when repeating duplicate with a rotated object.: But I believe the behaviour is not correct. I agree, this looks like a bug, added it to the backlog.
  • Context panel: how to reorganize
    @Subpath @Boldline Thank you both for your replies. I'm on W & it is under View > Customize...
  • Setup new document in pexels unit, got the wrong artboard size
    @mtinra Added this to the backlog.
  • Second chance for pick a key object in alignment
    @mtinra said in Second chance for pick a key object in alignment: Sorry for flooding the board. Feel free to post as many ideas, bugs and questions as you have on the forum. I have personally benefited from many questions and answers as well as the suggestions others have brought up over the time I've been using Vectorstyler. What I appreciate most is the way the developer, @VectorStyler truly listens to the ideas presented and considers their implementation as well as fast turnaround on bug reports and the like.
  • Click on layer widget should not active layers rename
    @mtinra Yes, there is a small bug here when, clicking on the layer name after clicking away should not start editing. The way it was intended is that if the layer name is clicked again (not yet a double click) then it should open for editing. This will be fixed ASAP. As for the double click editing: that can be enabled using the Layer panel menu Panel Options command, with the Double Click Renames checkbox (bottom-right).
  • Wrong object position when pasting on new layer
    @b77 for me if I put back the old files, it go wrong again. It may has somthing else on my machine to trigger the problem
  • Question about saving symbols
    @visualrevolt said in Question about saving symbols: I would like to see something similar to AD. When you drag and drop symbol it stays in the library. These are called presets in VectorStyler. You can create a symbol preset using the Presets panel. And these will be available in other documents also.
  • Questions about creating and using a new color palette
    @VectorStyler thank you for the guidance will follow your advice
  • Live paint/shape paint
    @Sarah-Austen said in Live paint/shape paint: @Subpath any news/progress on the bug? these are questions for @VectorStyler (he already answered ) I am just a normal user like you
  • Printing paper orientation
    @Harry This seems to be a bug, added it to the backlog.
  • Clarifying settings
    @Boldline said in Clarifying settings: There's also a setting on that sets my rotation of an object to designated amounts. it feels like the snapping it on but it's not... If I take an object and grab a corner with the transform tool and try to rotate it, it's not a smooth rotation. I hope that makes sense Is it Prefs > Editing Options 1 > Angle Constraint? This value is for rotating with Shift.
