    • syllieS
      Trace of line drawings
      @syllie thank a lot for taking the time these are really helpful videos
      Non modal Panels ?
      @VectorStyler said in Non modal Panels ?: In some cases this might be possible to implement. i would consider this as a long term thing even though I find this very useful and I guess that it also affects only a few panels Edited: One more thought came to mind. If we had a scripting language in VS, these things could perhaps be solved in this way.
    • IgullI
      Drag Object to Scroll
      Neil
    • IgullI
      Workspace Locking ?
      @b77 said in Workspace Locking ?: (You didn't use the search field under the Help menu? ) I did, but I wasn't looking for the word 'panel', I was looking for workspace Neil
    • syllieS
      Any way to move 2 selected anchor points in opposite direction?
      @syllie said in Any way to move 2 selected anchor points in opposite direction?: Step wise interactive change would have been nice I added this to the feature request backlog.
    • syllieS
      How did I create this 2nd artboard?
      @syllie said in How did I create this 2nd artboard?: Select artwork + RMB click with artboard tool creates a new artboard This part could be a bug. Will be fixed ASAP.
    • syllieS
      Magic Wand Selection & composite shape
      @syllie Can be replicated. This seems to be a bug, will be fixed ASAP.
    • syllieS
      Cannot assign shortcut for Select -> Select Similar -> Fill Color ?
      @syllie Yes, those are not separate actions. I will try to improve this for 1.2
      Am wondering if there's a way to assign two different shortcuts to a single command? e.g. Zoom to Artboard I could choose to use Control+0 or Control+0 (from the numeric pad).
      Watching Ignoring Scheduled Pinned Locked Moved shortcut keys
      @syllie Yes, it is in the backlog and not yet implemented.
      Auto-snapping a shape to 90 degrees keeps shape from being rotated freely
      @VectorStyler ok no problem. Thanks for the explanation. I'm glad this is fixed and improved upon already for a future update. Sounds like it will be a real game-changer when it's officially released. I can make do for now until then.
      Text on path aligned to "ascent" leaves large gap at top between words and path
      @vectorstyler @b77 thank you both for explaining. That makes sense now.
      Unintentional Opacity in a Noise Gradient
      @Subpath it should work with Software at least in all cases, so this might be a bug unrelated to the GPU.
      Can PDFs be exported from VS with layers honored?
      @VectorStyler ok no problem. It's not an urgent thing. In the long term it would be a great addition to add layers to PDF because it would give VS an alternative export with layers option besides strictly native VS files.
      Colorize: Randomize dose not included the last color in palette
      In this case, it should be a random deselected but it could be anything, a new selection mode or a new tool or command but it is not high priority. Thanks
      "Reselect" tool purpose?
      @Boldline Agree, no need to make it an entirely new option. It would in essence be a Reselection of the last Deselected / Dropped regular selection set. Regardless of how the Selection set was established. So Reselect would be active from a "No Selection" status. It would act like "Undoing" a Deselection, as @b77 described.. /Lars
      Align does not always seem to do the right thing
      @Boldline Can be replicated here also, it is a bug.
      Status bar show wrong information.
      @mtinra This seems to be a bug, and can be replicated here also. Added it to the backlog.
      Weird behavior when repeating duplicate with a rotated object.
      @syllie said in Weird behavior when repeating duplicate with a rotated object.: But I believe the behaviour is not correct. I agree, this looks like a bug, added it to the backlog.
      Context panel: how to reorganize
      @Subpath @Boldline Thank you both for your replies. I'm on W & it is under View > Customize...
      Setup new document in pexels unit, got the wrong artboard size
      @mtinra Added this to the backlog.
