    @fewerjunk This might also help: https://www.vectorstyler.com/forum/topic/3045/creating-seamless-pattern-for-pattern-fills
  • Combine Three Elements
    @Buntstift Press Cmd-J to close that path.
  • Cut a selected path into two pieces with the knife tool?
    @Buntstift Thanks for taking the time to share what you wanted changed in VS. Keep sharing the issues you run into and any ideas for improvement. New builds with updates come out a lot faster than with the competition!
  • Clipping within text ?
    @VectorStyler Thanks, duly noted To recall what to do in the future , I'll will save the post
  • Question about the "Tiling Pattern Conten" role for seamless Pattern
    @Subpath I think this depends what is inside a pattern. For a regular boxed pattern, there are also options to flip every other tile, that might help in creating seamless patterns.
  • Disable Guide Edit Option when Zoom View tool is active?
    @b77 said in command + 1, command+2 and command+3 shortcuts control both segment type and zoom out: @VectorStyler and @Ingolf Is adjusting opacity needed when in shape editing mode (A)? I would revert to simple 1, 2 and 3 for these commands. Oh Yes - very much needed. But without modifier of course.
  • Simple Rotate Question
    @b77 said in Simple Rotate Question: May the 4th be with you.
  • Set the Rotation Point manually doesnt work as expected
    @syllie said in Set the Rotation Point manually doesnt work as expected: I re-read this quite a few times, but cannot wrap my head around it. I got the message that it is complicated Yes, it gets a bit complicated. But it is basically about having the option to rotate things from the center (or a corner), without changing the rotation center.
  • How I can cut a selected Path into two piece
    @b77 said in How I can cut a selected Path into two piece: A suggestion I have for the Knife tool is making it cut AND split the path in two separate objects. This exists, but there seems to be a regression with the new intersection mode and separate does not work when the margins / nodes are overlapping.
  • Multiple deletes required to fully remove all selected nodes
    @Boldline Replicated the problem. It should be deleting also with that option disabled. Will be fixed ASAP.
  • Custom Palette and colour groups - how does this work?
    @syllie Not dropped, just requires a bit more thinking But it is working now, as expected except the preview in the Output column.
  • How do I … ?
    View „Enable snapping“ was selected. Now I found the on/off switch. Many thanks!
  • "Quick Look" on Mac
    @Boldline 268.5 MB is not the universal. I will test this again if to find out what is going on.
  • Unlimited Undo's
    Welcome to VectorStyler! I don't see a way to setup unlimited undo, but you can change the undo steps here in Document Setup (Cmd-Shift-P): [image: 1682899441819-screenshot-2023-05-01-at-03.02.08.png] Also: the History panel (Ctrl-H) has an Undo/Redo slider.
  • Why does this shape lose integrity?
    syllieS
    @VectorStyler At the time I was just playing with the functionality and I posted it as question as it did not even occur to me it was unexpected behaviour. As such, I did not keep the original shape that I worked with to create my variation. I must have hit some extreme or applied an effect twice perhaps, as you can see in the shape, the petals are sort of heart shaped (indents are alternating). I do not even have a clue how to replicate the base shape. I did play a bit with the functions option too (S-Curve, Hanning, Sphere, Pinch). Not sure if this is worth pursuing. I now know that my nodes were not cusp, and I know how to correct this issue if it occurs. [image: 1682369530059-62e9771c-448c-4d38-9b7f-f7632fca7d92-image.png]
  • Shapebuilder question
    syllieS
    @VectorStyler I've sent you the file. I read that you were working on an overhaul. Thanks.
  • Path Sketch Tool extract from closed shape not working?
    @VectorStyler If the 'Exclude' boolean operation was named 'Subtract', 'Subtract' would be used here as well, and there would be no confusion about the meaning ('Exclude' can be misinterpreted).
  • Easiest way to do "Pucker" effect in VS?
    @syllie your welcome, indeed VS offers some playground to have fun . . btw related to corners @VectorStyler made already a video how to edit your own corner here the video with some corner magic . . I create a Tutorial a while ago, which shows a bit the power of smart shapes for pattern making Here the link: https://www.vectorstyler.com/forum/topic/2142/the-shape-of-things-using-parametric-shapes-for-pattern-making
  • How to Deselect in node tool?
    @Raven I think this could be a bug with the Deselect command. Will be fixed ASAP.
