• Intertwine Effect: Where is it?
    34
    @Daniel looks great! Btw. would it be possible to create a thread about this in the tutorial section? That way it would be easier for other users to find.
  • Blend not smooth
    I'm curious what zoom level that was
  • Parallele spline
    @ZATOPEK This seems to be a bug. Aligning the stroke to the center will show the correct stripes. I will try to find a solution for this.
  • blend fonction
    ZATOPEKZ
    @VectorStyler THANNNNKSSSSSS
  • A strange offset on attempt to Drag to Duplicate
    @VectorStyler Fixed in recent update
  • A question about Repeater Intensity
    @Li-Xiao said in A question about Repeater Intensity: Will the backdrop slope automatically switch to directions? The backdrop slope is using the background image "gradient" direction, so the answer is yes, but it depends how it is used.
  • How to make VS focus an item in layer panel?
    @VectorStyler Splendid, thanks, and even with short key ctrl-shift-K [image: 1766049131420-5b59ae23-4e0b-4ab4-b12c-bb9e2bcfea73-image-resized.png] [image: 1766049395460-4899591d-cb17-4d05-8184-3f8c8640f0d5-image.png]
  • How do I select and cmd-G grouped shapes to a new group?
    Thanks Yet if there's many shapes with exclusions it may (ie texts) it may be cumbersome. Is there a dedicated function for this? @Boldline said in How do I select and cmd-G grouped shapes to a new group?: the interior fills of enclosed shapes can be made a different color
  • How to configure the image tracer?
    @Raaskot your always welcome nice to hear that this ideas was helpful
  • Where is the gradient for scale in a repeater?
    C
    Perfect, thank you. Don't know why I didn't see that.
  • Repeater option to edit shape directly with existing repeater preset
    @VectorStyler oh great! Thank you for fixing that
    @William-Kansepa , interesting I don't see a big problem with that, since it's always easy to use a kind of dummy group (without colors). Or to plan a bit in advance. Alternatively, it is always possible to use multiple mirror groups. By the way, one way I found to add more objects to a mirrored single object works by first creating a Symbol of it. Then you use that Symbol and mirror it. Afterward, you can replace that Symbol with any objects or add more by selecting the objects and using the "Replace Symbol with Selected Object" button in the Symbols panel.
  • Question about the Intertwine Tool
    @Gremriel I tried it out and discovered something interesting. Firstly, I had the same problem as you: the intertwining effect disappeared when I deleted the outline. After that, the intertwining effect couldn't be created again. The reason for this could be that when you ungroup the objects, there are now four copies of the red object. I think this has something to do with the effect itself. If you delete three of the four objects, you can apply the effect again. [image: 1765573674592-intertwine-effect.png]
  • Node Editor vs Shape Editor tools
    @William-Kansepa said in Node Editor vs Shape Editor tools: What are the major differences in functionality between the Node Editor and the Shape Editor tools? yes, this is a new thing in 1.3: Node Editor: will edit the nodes of the top effect, or the object shape Shape Editor: will always edit the object shape, regardless what effect is stacked on it. These two tools are the same of the object contains no shape effects
  • DXF Versions
    @VectorStyler Thanks for the quick reply. If you have some older DXF files that do not import, please send… Thanks, but I'm not really needing that. I'm just making some examples to demonstrate the decades-old "polyline" problem of the CAD>DXF>Bezier workflow (which I don't recommend, if at all avoidable). So I just wanted to make sure not being able to open the R12 files I'm using to demonstrate, is not unique to my installation. I can open R14 versions of the same files, (which do not demonstrate the polylines issue, but break curves at every path segment). JET
  • Not sure how to create a line tapering repeater
    1k Views
    @Boldline said in Not sure how to create a line tapering repeater: What is the best way to create this because [when I do it the usual way, nothing happens.] There are at least more than five ways in Repeater to achieve the result you want. If it must be done using only a single line, with the gradient controlling the line’s thickness, the best way is to use variables. Please see the video. https://youtu.be/Hyg6LJTxftQ
  • Clip to Arboard setting as an icon... is possible?
    @VectorStyler Great! Thanks again. I grouped the three Artboard clip icons (dim outside, clip to artboard and show outside). Very useful. The icons are quite similar, i will make some modifications to identify easily.
  • Search in application
    @VectorStyler Yes is very usefull, specially for newbies like me. Gimp has this feature: [image: 1764952346921-d6909804-0fa3-43ef-97e7-a6fa3c31be50-image.png]
  • Why can't the join tool be invoked in some cases
    @EricP Aha Your welcome Btw. the "Extend Path Tool" could also be helpful in some circumstances by working with Spirals (should converted to curves first of course) [image: 1764673450253-extend-path-tool.png]
  • Files not Exporting
    export artboards
    1k Views
    C
    [image: 1764518985732-26e46ca0-3529-4165-bba5-297080b9dc67-image-resized.png] Here's the export window and me prompting it to save in (D:) [image: 1764519005007-edb17fd7-9f36-49f3-b216-548e8e350a1e-image-resized.png] Not a network, just a partition in my SSD
