• Text Frame gets added accidentally when editing offset path result
    @VectorStyler That makes sense. Thank you for checking into that for me. I'll have to remember to always click on the top menu bar area to detach from the color palette before copying and pasting
  • New Artboard moves touched locked Object
    @monsterfox said in New Artboard moves touched locked Object: @VectorStyler Actually, I feel that the drawing boards shouldn't be overlapped. It doesn't seem to make much sense. In most cases yes. But it can also be used to cut for export or print different parts of an artwork, with some overlap or rotation.
  • Je veux testé vectosyler
    @VectorStyler That's still good news.
  • New shortcut don’t apply problem ...
    @VectorStyler I know, but it would be helpful for new and occasional users, that the icon changed accordingly, temporarily, whilst pressing "Option".
  • Direct Shape Transformation
    @William-Kansepa I will need a recording (Shape Effects panel included), and then send me the vstyler file also.
  • Key Shortcut for Color Picker ?
    @Subpath It is a customizable shortcut. But I will find a solution.
  • Scatter Brush with random colors while painting ?
    @VectorStyler said in Scatter Brush with random colors while painting ?: @Subpath said in Scatter Brush with random colors while painting ?: Like this pic of mine made with another vector graphics tool What tool was that? I don't remember the name, but it was an Adobe Flash Air tool. Thanks to the Flash script/programming language, it has some for very unusual but nice painting Tools. . . A somewhat similar Program is "Alchemy" (PC/Mac) which still work with Win 10. This is offers also unusual vector graphics painting tools. My favorite tool are Pull Shapes. With Pull Shapes you could put vector graphics shapes from a PDF file randomly on the canvas. You are able to use your own shapes, just save them in a PDF file and place this file in Alchemys Pull Shapes folder. Here a Link to the latest Beta https://al.chemy.org/download/ . . Here a Video Picture made with Alchemys Pull Shapes [image: 1747372382438-pull-shapes.png]
  • Snap at midpoint
    @VectorStyler Thank you
  • Align the dimensions
    @monsterfox I added this to the backlog.
  • Change the shape of the eraser tool
    @Subpath said in Change the shape of the eraser tool: Brush Size for the "Path Eraser Tool" is not shown Yes, I was thinking of a different tool. I will add this.
  • Keep latest brush features in memory? Any Bucket Tool?
    @VectorStyler Great!
  • Controlling stroke/brush endings?
    @Raaskot said in Controlling stroke/brush endings?: I need a brushed stroke with full - not zero - width at the start and in the end As mentioned by @Subpath the brush just stretches a vector content. The only way to have what you need is to create a new custom brush where the endings contain a straight line that is the height of the brush content. Or use a solid stroke instead.
  • Export .SVG in mm (millimeter) instead of pixels
    @VectorStyler Wonderful! Thank you so much for all your updates to the software. It has become my "go to" vector app.
  • 'Clear all character overrides' - what does it do ?
    @encart said in 'Clear all character overrides' - what does it do ?: What about tracking, scaling, etc? Am I able to reset all of the parameters? Everything that was applied locally (not the whole text)
  • Option to offset and position the text on a path has disappered
    @VectorStyler Cool, thanks! [image: 1745489804323-9a09fa92-baad-44ec-9832-154e4252b073-image.png]
  • How do I select and import multiple images into VS?
    @VectorStyler Wonderful, confirmed, thanks!
  • No multiple PDF page export
    @Raaskot I think that the "Selected Artboard" might be misleading labeling. it refers to the artboard indexes listed in the Artboards field below (also the 1-4 type of selection works). The "Export Artboards" UI is more intuitive for this.
  • Unwanted Space (gap) in Text Frame
    text frame
    @MWK Got the, file. Here I can drag the text frame up the the baseline of the 3rd line. Or was the problem with the double+click resizing?
  • I spot a shortcut key difference.
    @Subpath Yes, there are known some issues with the default shortcuts and keyboards with other languages.
  • Can tilted text be aligned along a path?
    @monsterfox The transforms (and effects) on the text are not used when the text is aligned to a path. You can group the text with the path and then apply an effect on the group.
