  • Size adjustment problem when using the warp, liquify, noise etc. tools
    @Ingolf I will add this to the backlog, as an improvement idea. The right click could be doable (no need for context menu in this case). Also the brush width will be added to the context panel.
  • Usability: corner tool
    @vectoradmin Thanks!
  • Important requests regarding usability
    @Ingolf I will add these to the backlog. Some are easy to do as options. A status bar is planned to be implemented in the near future. I will try to fix the panel redraw issue. The problem is with the Windows port.
  • New Member/Helpful Beginner Tips Section
    That's great, thanks
    @vectoradmin ok I can see what you mean - the option "Paste Above" has a key command just as "Paste Below" does.
  • Saving Font information in the document
    @encart Maybe some cases of these can be handled with batch export, or object export? (using the Object Export panel)
  • VS switch to opened file when opened from outside VS
    @Boldline
  • perspective grid guide
    I don't know if this is really helpful. But for Windows users there is a somewhat unusual solution. If you can spare a few Bucks ($30.-). The tool is called "LazyNezumi" and is actually meant for bitmap programs but works also with vector programs (e.g. Affinity Designer). Also with VectorSTyler, tested. But you have to turn off line smoothing. This tool captures the window of your graphics program, from then on you can use the rulers as if they were built in. The ruler mode can be switched on and off. Besides, you can say that it has a lot more to offer than just a perspective ruler. Here there Homepage LazyNezumi Here how to start with How to Start Btw. dont forget that you can paint your Design in a Bitmap Program and trace it later with VS build in Vector Tracer.
  • Adding prdefined sizes list for width and height.
    @encart You post reminded me of what Affinity and Illustrator CC offer with a new document setup menu. I use one size document most of the time, but I know I'd appreciate being able to open a predefined artboard setup based on intended use built in to VS. It would also be nice to store several artboard sizes in a personalized presets section [image: 1636307898370-fa46e808-d4d2-4f86-983e-7a7f723be131-image-resized.png] [image: 1636307929432-99429166-8102-4e5a-99c2-ec887aed8ad4-image-resized.png]
  • Mouse Wheel Sideways scrolling would be nice
    ambrosA
    Yes I’ve got that checked… Helps immensely..
  • Lock and Unlock Selected Guidelines using Object>Lock/Unlock
    @Boldline It is not possible to lock guidelines individually, only in groups. Guideline groups can be created and managed in the Guidelines panel. Currently guidelines are in groups and it is possible to set color, lock/unlock, show/hide or activate/deactivate per group. But, the guideline group handling in the panel could be improved. I could not replicate the guideline disappearing issue. When I lock the guidelines, they are still visible.
  • Guideline alignment and distribution control
  • Isolate sub-layer by completely hiding the rest of the layer
  • Tip - Software for Mograph like Vector Animations
  • Stamping Of Objects
    @vectoradmin Hello, Thanks you. Best Regards, KF
  • Guides panel Option to duplicate and flip
    @Boldline I add this to the requested features list.
  • Built-In "Vector Inspector" for VS?
    @Boldline Interesting feature. I will add this to the list of feature requests.
  • Keep Important Info Boxes on top of VS desktop
    @vectoradmin The save box is working correctly. It happened with the update panel today and with the recovery panel the other day for sure... I'll keep a closer watch and update you
  • A better Place for the Stroke-Width-Tool on your Website
