  • Inspiration - context sensitive object toolbars
    Just to point it out, this could easily be a customization option. Rather than being just group/ungroup, consider an option to pick from the existing toolbar commands and add smaller versions of them to the bounding box, on a selected side of it, perhaps specifying which ones should appear for a given type of object, or when there are multiple objects selected, etc. It would basically turn an edge of the bounding box into another customizable toolbar.
  • Inspiration - interactive perspective feature
    @Ingolf said in Inspiration - interactive perspective feature: The visual approach has the advantage, though, that you can play freely with it and visualize all kinds of perspectives live and fast. True.
  • Inspiration - interactive drop shadow
    @Ingolf Somewhat different, but once the drop shadow is added in VS, it can be edited interactively (as most effects): https://recordit.co/j2gt7ZERqT
  • Inspiration - interactive replicate
  • Improving color palette selection of existing colors
    @Boldline The color drag&drop between palettes has been added in build 1.1.008
    @Boldline This feature has been added in build 1.1.008
  • Sliders default values
    Maybe relevant: Sliders and their position
  • A way to show Keyboard Shortcuts
    @Subpath said in A way to show Keyboard Shortcuts: @Ingolf In Cavalry it shows only the shortcuts to the relevant tool. Yes, of course it shall only show shortcuts for the active tool. That is the point of that info. Just like the information shown in the status bar in Affinity or Inkscape about shortcut keys for the active tool - but displayed like this instead: [image: 1642153669334-8e9e9997-374d-40cb-92ed-0d9371bc1d69-image.png] But in VS there could also be a switch in the preferences to turn this on or off. Yes, also in the preferences but not only. I would myself (want to) enable or disable it quickly several times a day without going all the way to preferences. It might also be helpful if we could set the transparency of the text info individually. Indeed.
  • License information
    @Ingolf Added this to the backlog.
  • Repeaters additional options
    @Boldline said in Repeaters additional options: This would be an alternating grid: That can be achieved by setting the first Shift value to 50% and setting a negative spacing.
  • Key down shortcuts ideas
    @vectoradmin It is my present solution, which works quite well, but it is certainly not universal. Requires external application installation, customization, is less efficient, sometimes glitch occurs Is the result of using point 1. more universal, will work with most pointing devices easier to remember shortcuts and reduce the number of them may improve the use of the stylus may improve your experience when using a touchscreen device it gives good possibilities for further expansion uses the current drag mechanics. In the case of point 3, I see a lot of imperfections in this solution and it may turn out that it will be faster to point to the classic align panel than to look at the keyboard to trigger a popup I don't know if it will speed up the workflow or if it will be precise enough for everyone. The amount of features available is already overwhelming for new users, but I think together we can create some points that will be unique to VS
  • Put all selection modes as pullouts from the transform tool
    19k Views
    Adjusting my chef toque here… Well, if the developer would allow these small tool panels to be docked like this on top of the toolbox, would that be bad? [image: 1641406018771-stacked.png]
  • Reset Artboard Dimensions interactively
    @vectoradmin Thank you! that makes sense now. I appreciate you showing me
  • New Document Setup/ Template Panel
    @Boldline I add this to the feature request backlog. Technically, it is doable.
    @Boldline I add this to the backlog.
  • FR: Preference for regular Windows cursor + Cursor on Screenshots
    X-RaymX
    @vectoradmin said in FR: Preference for regular Windows cursor + Cursor on Screenshots: but I'm not sure what is going on with the screen capture hiding the cursor. Not sure either cause it works on other apps: [image: 12Z1Mq0.gif] See how it appears in affinity designer but if I minimize the window, only the cursor only appears on the first frame and then is stucked, while we can see I am clicking and dragging (but without cursor) just left to it. EDIT: it seems to be in fact related once again to using VectorStyler with tablet (and probably using Windows Ink). it works with mouse [image: vTSlXCZ.gif] BTW, you can see how pixelated is the native VectorStyler cursor compared to native windows one.
  • Better defaults make for a good first impression
    @Ingolf I agree this would be nice to have, however the prefs files need to be made by users who are very familiar with the latest versions of AI, CDR or AD. Having worked before for many years in CDR, I tried to make a preferences file that mimics it, but I didn't use CDR since 2018 and even then it was X7 β€” not the newest version. Then two years later or so I trialed the first version of CDR for Mac, and the object selection method was changed from 'select only what is inside the marquee' to 'intersecting selection', IIRC. (Maybe this is only on the Mac version? I don't know). That's basically why I gave up, and also because VS has defaults I like for the most part. But if anybody is interested, I can send the one for CDR to use it and maybe take it further.
  • FR: Randomization for Layers Transform Properties and Colors
    X-RaymX
    @vectoradmin I had prepared the screenshots already: https://i.imgur.com/6bWKbtX.gif Win 10 x64
  • TIP - Halftone Generator - Bitmap to Vector graphics (.SVG)
    29k Views
    @vectoradmin I know it allready play a bit with the Repeater, like it
  • Web based example of vector based halftones
    @vectoradmin said in Web based example of vector based halftones: "halftone wizard" hahah Nice!
