      Symbol Tinting Brush only works one time
      @fde101 I will try to replicate this.
    • IngolfI
      The tooltip in the shape effect editor (4-point)
      @Ingolf This problem should be fixed now.
    • encartE
      Locked proportional width and height in the shape's properties window.
      @encart This problem should be fixed now.
      Offset Path preview disappears when set to under 0.186 inches
      @Boldline This problem should be fixed now.
      Offset path not returning final result to 100% - corrected with VS restart
    • IngolfI
      Color panel slider issues - part 1 (hue accuracy)
      It is
      Can literally nothing be added or deleted or modified on a locked layer?
    • encartE
      Strange behaviour of Radius corner field.
    • encartE
      Bolean Exclude gives unexpected results.
    • encartE
      [Move window] Have to click 'Cancel' button 3 times to close it.
      Vertical text in PDF is not proper
      17k Views
      @ash-f Font exporting to PDF and Postscript has been significantly improved in recent versions. Let me know if this issue still occurs.
      Dragging VS to another screen and back causes issues
      @Boldline Tried to replicate this with a Mac Mini dual screen setup, but could not. Is the problem still occurring?
    • IngolfI
      Color panel slider issues - part 4 (too much accurary?)
      @Ingolf This problem should be fixed now. BTW: enable Preferences -> Number Editors -> Limit Precision, to scroll with reasonable amounts.
    • IngolfI
      Color panel slider issues - part 2 (brightness accuracy)
      Parts of Design Disappear Momentarily as I edit other parts
      @Boldline There have been improvements in using dual display setups. Let me know if this issue occurs.
      Automatic Vertical Roman option not working properly
      @ash-f This problem should be fixed now.
      Holding down shift causes node path to go wonky
      @Boldline Holding down Shift key will restrict to horizontal or vertical movement only.
      Align to selection does not seem to be working as it should
      @Boldline Aligning selected nodes with the Alignment panel should work now.
    • IngolfI
      Referenced duplicate+source and clone source not exported to SVG
      @Ingolf Exporting reference objects (with Named Groups option enabled) should work now.
    • IngolfI
      Change color mode - stroke goes from none to color
      @Ingolf There is a Select Color Mode option in the Color panel menu, to control whether the color mode change causes the selection of the color or not.
